Mobile Workstation Cart with Monitor Mount, CPU/PC Holder, Keyboard Tray, Ergonomic Height Adjustable Desktop Computer Cart, Rolling Mobile Standing Workstation on Wheels - Portable Stand-Up Cart (WKSTNCART).
Product Description | StarTech.com Mobile Workstation Cart with Monitor Mount, CPU/PC Holder, Keyboard Tray, Ergonomic Height Adjustable Desktop Computer Cart, Rolling Mobile Standing Workstation on Wheels - Portable Stand-Up Cart - cart - for LCD display / keyboard / mouse / CPU - black | Product Type | Cart | Dimensions (WxDxH) | 85 cm x 64.5 cm x 140 cm | Adjustable Height | 1.3-1.6 cm | Tilt | -30° to 30° | Rotation | -180° to 180° | Adjustments | Height, tilt | Weight | 18 kg | Recommended Use | LCD display / keyboard / mouse / CPU | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 8 kg | Material | Steel | Colour | Black | Wheels Qty | 4 | Package Content | 4 x M4x12 screws, 4 x M5x12 screws, hex key (5mm), CPU strap, column, hex key (6mm), 4 x M4x16 screws, 4 x spacers, caster wrench, M6 wrench, mouse pad, 4 x M5x16 screws, keyboard tray, CPU holder, base, 6 x M8x30 screws, 2 x M6 nuts, 4 x washers (large), 4 x casters, 4 x washers (small), column cap, 6 x M6x6 screws | Manufacturer Warranty | 2-year warranty |
General | |
Width | 85 cm |
Depth | 64.5 cm |
Height | 140 cm |
Weight | 18 kg |
Material | Steel |
Colour | Black |
AV Furniture | |
Type | Cart |
Shelf Qty | 1 |
Cable Management | Integrated cable management |
Wheels Qty | 4 |
Dimensions & Weight Details | |
Shipping Dimensions (WxDxH) / Weight | 110 cm x 72.5 cm x 17.7 cm / 20.1 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
