The ST4300USBM Mountable 4-Port Industrial USB Hub (USB 3.0) offers a simple way to expand a systems current USB capability by providing 4 additional external USB 3.0 ports from a single USB 3.0 host connection, with speeds up to 5 Gbps.
Designed for extreme operating environments, this industrial-grade hub provides reliability under almost any condition and can be securely mounted to most surfaces.
Fully compliant with the SuperSpeed USB 3.0 specification, this industrial USB hub is backward compatible with USB 2.0 and 1.x specifications for simultaneous support of older USB peripherals or even older systems without USB capabilities.
Product Description | StarTech.com 4-Port USB 3.0 Hub - Metal Industrial USB-A Hub - Wall or Desk Mountable USB Data Hub - TAA Compliant USB Expander Hub (ST4300USBM) - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x SuperSpeed USB 3.0 | Features | Wall mountable | Compliant Standards | USB 1.1, USB 2.0, USB 3.0 | Power | DC 7 - 24 V | Dimensions (WxDxH) | 6 cm x 15.2 cm x 2.4 cm | Weight | 480 g | Colour | Black | System Requirements | Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ITB20D3250, MSDREADU2OTG, PEXUSB3S23, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, SVA12M5NA, USB312SAT3CB, USB315CB2M, USBLT1MW, USBLT1MWS, USBLT2MBR, USBLT2MW, USBLT30CMW, USBLTM1MBK, USBLTM1MWH, UUSBHAUB1RA, UUSBHAUB3, UUSBHAUB3LA, UUSBHAUB3RA, UUSBHAUB6IN, UUSBHAUB6RA |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Status Indicators | Port status, power |
Expansion / Connectivity | |
Interfaces | 4 x USB 3.0 Type A , USB 3.0: 1 x 4 pin USB Type B |
Power | |
Power Device | External power adapter |
Voltage Required | DC 7 - 24 V |
Miscellaneous | |
Colour | Black |
Compliant Standards | Plug and Play, FCC, RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition |
Dimensions & Weight | |
Width | 6 cm |
Depth | 15.2 cm |
Height | 2.4 cm |
Weight | 480 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 55 °C |
Humidity Range Operating | 5 - 95% |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 85 °C |
Compatibility Information | |
