StarTech.com Portable 4 Port SuperSpeed Mini USB 3.0 Hub - White
£25.59
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Connect up to four USB 3.0/2.0/1.x devices simultaneously at their maximum speeds
  • Compact design with a built-in cable for ease of use and portability
  • Type: USB Hub
  • Interface: SuperSpeed USB 3.0
  • Speed: 5Gbps
  • Ports: 4
  • Form Factor: External
Product codes
chevron icon
chevron icon
Add four external USB 3.0 ports to your notebook or Ultrabook with a slim, portable hub. The ST4300MINU3W Portable 4 Port SuperSpeed Mini USB 3.0 Hub (White) lets you expand your USB connectivity by turning a single USB 3.0 port into four external USB 3.0 ports. The integrated cable design makes this mini USB hub the perfect accessory for your Mac / PC notebook or Ultrabook computer.
The 4 Port USB 3.0 hub supports USB 3.0 data bandwidth (5 Gbps - up to 10x more than USB 2.0) and is backward compatible with USB 2.0 and 1.1 devices, ensuring flawless performance from all of your USB peripherals/devices, regardless of their age.
Ideal for home and business users who require portability, the external USB 3.0 hub is USB-powered and features a rugged, compact design with a built-in cable so no additional cables are needed to connect the hub to your system.
chevron icon
Product Description StarTech.com 4 Port USB 3.0 Hub - Multi Port USB Hub w/ Built-in Cable - Powered USB 3.0 Extender for Your Laptop - White (ST4300MINU3W) - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Features USB powered
Compliant Standards USB 1.1, USB 2.0, USB 3.0
Dimensions (WxDxH) 3.9 cm x 7.6 cm x 1.4 cm
Weight 38 g
Colour White
System Requirements Apple MacOS X 10.0 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Designed For P/N: FCREADMICRO3, MSDREADU2OTG, MSDREADU3CA
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£25.59
