Add space for your VGA port and connect a VGA cable even in tight installation spaces. This Right Angle VGA to VGA Cable Adapter Type 2 provides one right angled VGA male connector and one standard VGA female connector - allowing you to connect the cable to a VGA female port, even if space around the VGA port is limited.
Product Description | StarTech.com Right Angle VGA Adapter - Right Angle VGA to VGA - Male/Female - Type 2 - Male VGA to Female VGA (GC1515MFRA2) - VGA adapter | Type | VGA adapter | Features | 90° connector | Connector | HD-15 (VGA) - male | Connector (Second End) | HD-15 (VGA) - female | Compliant Standards | RoHS | Colour | Grey | Manufacturer Warranty | Limited lifetime warranty | Designed For | P/N: DP2VGAMM6, DP2VGAMM6B, HD2VGAMM6, MXT101MM, MXT101MMHD15, MXT101MMHD6, MXT101MMHQ20, MXTHQMM10MA, MXTHQMM15A, MXTHQMM15MA, MXTHQMM25A, MXTHQMM2MA, MXTHQMM30A, MXTHQMM35A, MXTHQMM50A, MXTHQMM5MA |
General | |
Colour | Grey |
Connectivity | |
Connector | 15 pin HD D-Sub (HD-15) - male |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female |
Miscellaneous | |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Compatibility Information | |
