StarTech.com Rugged Hard Drive Enclosure
£35.56
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Protect your data even in the toughest field conditions
  • Military Rated (MIL-STD-810G) drive enclosure provides exceptional shock resistance
  • Outstanding water and dust resistance with IP-54 rating
  • Type: Storage enclosure
  • HD Size: 2.5"
  • Stock Status: In Stock
Product codes
Gear up for the field with portable hard drive protection. This rugged drive enclosure redefines data protection for on-the-go professionals. The military-grade construction protects your sensitive data from harsh field conditions. It makes sure you're equipped for unexpected challenges with a ruggedized water, dust, vibration and shock resistant enclosure.
Keep your data safe and secure even through sudden downpours or dust storms. The robust enclosure provides superior water and dust resistance with an IP54 rating.
The rugged drive enclosure is enveloped in a silicone protective sleeve, and engineered to help protect your drive from accidental and unexpected shock, vibrations, and drops. It's Military MIL-STD-810G rated and test-proven to withstand drops of up to 4 meters (13 feet). It was drop tested using a solid-state drive in the enclosure.
Wherever you go, the rugged drive enclosure delivers reliable data protection, inside and out, with a tough-wearing exterior casing. The flexible shock-resistant silicone sleeve hugs the entire perimeter to provide an extra measure of protection, absorbing the impact of accidental bumps, rough baggage handling or drops. Inside, an extra layer of silicone provides added stability and security.
It's easy to turn your 2.5in SATA III (6Gbps) solid-state drive or hard drive into external storage. Simply remove the silicone sleeve, open the latch to insert your 2.5" drive into the rugged enclosure, and plug the included USB cable into the computer or hub USB port. There are no screws or tools needed.
Save time in the field, by storing and transferring content quickly. Enhanced with UASP (USB Attached SCSI Protocol), this rugged drive enclosure performs with a 70% faster read speed and 40% faster write speed over conventional USB 3.0, when paired with a UASP-enabled host controller.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP enabled StarTech.com enclosure, and a SATA III (6Gbps) solid state drive.
Product Description StarTech.com USB 3.0 to 2.5" SATA SSD/HDD Enclosure - UASP Enhanced External Hard Drive Enclosure - MIL-STD-810G Rated Case (S251BRU33) - storage enclosure - SATA 6Gb/s - SATA 6Gb/s, USB 3.0
Device Type Storage enclosure - external
Bus Type SATA 6Gb/s, USB 3.0
Colour Black
Expansion Bays 1 x internal - 2.5"
Hard Drive Form Factor Compatibility 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Supported Devices Hard drive
Max Storage Devices Qty 1
Power Source USB bus
System Requirements Windows 8, Apple MacOS X 10.8 or later
Dimensions (WxDxH) 11.3 cm x 14.5 cm x 2.7 cm
Weight 200 g
Designed For P/N: HB30C1A1CPD, HB30C3AGEPD, HB30C3APD, HB30C3APDW, HB30C4AB, HB30C4ABW, HB30C4AFPD, HB30C4AFS
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Rugged Ha...
£35.56
