Easily clone or erase SATA and SAS drives, without having to connect to a computer. This standalone drive duplicator and eraser supports both SATA and SAS drives, making it a great fit for enterprise storage and data center applications. Compatible with 2.5" and 3.5" drive form factors, it provides a versatile and cost-effective drive management solution.
With the drive duplicator, you can clone SATA or SAS drives 1:1 at speeds of up to 13 GB per minute. It provides IT professionals and system administrators with a powerful tool to effectively manage drives for backend server infrastructure or drives distributed to organizational employees. It contributes to a more efficient workflow by enabling completion of duplication tasks without the use of a computer or software. You can quickly back up and archive data, duplicate data for disk imaging, or transfer content to additional drives for office professionals, medical staff, government personnel, or other employees.
The drive cloner/eraser provides four duplication modes including System and File, All Partitions, Sector-by-Sector (Whole Drive), and Percentage Copy.
Erase SATA or SAS drives with ease, without a host computer. As a drive eraser, the SATSASDUPE11 can erase two drives simultaneously and gives you a choice of six erase modes including Quick Erase, Secure Erase, 1-Pass Overwrite, 3-Pass Overwrite (DoD), 3-Pass Erase and Compare, and 7-Pass Overwrite.
The multiple erasure modes give you the assurance that data can be securely erased when repurposing drives. This alleviates concerns over privacy-related issues when erasing sensitive data, important to many professional offices such as medical, legal and accounting firms.
The drive eraser also enables you to keep a record of completed erase jobs, with built-in erasure logging, for auditing purposes. It connects to an RS232 serial printer to print a record of the erase procedure and confirm that the erase has been successfully completed. The printed receipt clearly shows you the time and date of erase, as well as the erase mode used.
The drive duplicator and eraser provides IT professionals with an easy-to-use solution in an office or server environment. It offers convenient menu navigation buttons and a built-in LCD display that clearly identifies the duplication or erase mode and task status. Since it is OS independent, no software or drivers are required.
Its standalone operation provides quick setup, without having to connect to a computer. You can easily transfer the device from room to room, to work on drives in different locations.
Product Description | StarTech.com 1:1 Hard Drive Duplicator and Eraser for 2.5"/ 3.5" SATA (I/II/III) & SAS (I/II) HDD SSD - LCD & RS-232 - Cloner & Wiper (SATSASDUPE11) - solid state / hard drive duplicator | Device Type | Solid state / hard drive duplicator | Colour | Black | Installed Devices / Modules Qty | 1 (max) | Supported Drives | SATA-600 / SAS-2 | Localisation | Australia, Japan, North America, United Kingdom, Europe | Built-in Devices | Status LCD | Storage Controller | SAS (SATA 6Gb/s / SAS 6Gb/s) | Hard Drive | No HDD | Power | AC 120/230 V | Dimensions (WxDxH) | 9 cm x 19.4 cm x 3.5 cm | Weight | 700 g | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Colour | Black |
Chassis | |
Supported Devices / Modules Qty | 1 |
Storage Controller | |
Type | SAS |
Interface Type | SATA 6Gb/s / SAS 6Gb/s |
Hard Drive | |
Type | No HDD |
Expansion / Connectivity | |
Interfaces | 1 x USB 3.0 - 9 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (male) , 2 x SAS - 29 pin internal SAS (SFF-8482) |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V |
Dimensions & Weight | |
Width | 9 cm |
Depth | 19.4 cm |
Height | 3.5 cm |
Weight | 700 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 20 - 80% |
