StarTech.com SPDIF Digital Coaxial or Toslink Optical to Ster...
StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter
£39.70
Delivery:
Standard: 1-3 working days
Key features
  • Support for digital coax or Toslink to RCA conversion offers versatility and saves the cost of hardware upgrades that would otherwise be needed for compatibility
  • Compact form-factor makes the device easy to transport and fit into almost any installation space
  • Type: Cable
  • Stock Status: In Stock
Product codes
Convert a Digital Coax or Toslink Signal to Stereo RCA Audio. The SPDIF2AA Toslink/Optical SPDIF to RCA Audio Converter lets you convert a 2-channel Digital Coaxial or Toslink/Optical SPDIF input signal into an RCA analog stereo output.
Perfect for home and professional audio applications, this SPDIF to RCA audio converter saves the cost of upgrading equipment for compatible connections, and offers separate Digital Coax and Toslink inputs for dual-function conversion. The small form factor design makes it suitable for installation into virtually any location, regardless of space constraints, while still providing a lossless audio signal. Plus, the digital coaxial or Toslink to RCA converter supports plug-and-play installation, saving you time and hassle.
Product Description StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter - Digital Audio Adapter (SPDIF2AA) - coaxial/optical digital audio converter
Product Type Coaxial/optical digital audio converter
Product Material Steel
Dimensions (WxDxH) 4.2 cm 2.7 cm
Length 5.2 cm
Weight 78 g
Colour Black
Designed For P/N: FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWTLTBAT, STNDMTV70, SVA5M3NEUA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com SPDIF Dig...
£39.70
