Duplicate one 2.5/3.5" hard drive to another without connecting to a computer, or backup multiple drive images to a library drive to restore PC/Server images easily. The SATDUP11IMG standalone SATA hard drive duplicator, lets you create an exact duplicate of a SATA hard drive (HDD) / solid state drive (SSD), or create a single backup library drive containing multiple images you can copy to additional drives at any time.
Reduce clutter with the SATDUP11IMG eliminating the number of drives required when creating backups of multiple unique drive images. Using a single backup library drive, you can store several unique drive images on a single SSD / HDD, ensuring fast duplication at 6 GBpm and minimal clutter. This is an ideal solution if you frequently re-image different computer systems, because it means you'll only have to carry a single backup library drive to restore multiple drive images onto different systems.
The versatile duplicator also offers standard one-to-one drive duplication in three different modes: file & system copy, all partitions copy and whole copy. This is ideal for one-time drive duplication, eliminating the hassle of creating a drive image for a one-time project.
With an easy-to-read LCD display and intuitive four-button menu operation, the SATDUP11IMG ensures hassle-free setup and control. The menu gives you push-button access to many value-added features that ensure simple task management such as: drive to drive duplication, drive to Image library backup and restore, and many more. It also provides numerous advanced setup options for experienced users.
The SATDUP11IMG is TAA compliant.
Product Description | StarTech.com 11 Standalone Hard Drive Duplicator with Disk Image Library Manager For Backup & Restore, Store Several Images on one 2.53.5 SATA Drive, HDDSSD Cloner, No PC Required - TAA Compliant - hard drive duplicator | Device Type | Hard drive duplicator | Colour | Black | Installed Devices / Modules Qty | 0 (installed) / 2 (max) | Supported Drives | SATA-600 | Localisation | North America, United Kingdom, Europe | Built-in Devices | Status LCD | Storage Controller | SATA (SATA 6Gb/s) | Power | AC 120/230 V - 50/60 Hz | Dimensions (WxDxH) | 13 cm x 8 cm x 3 cm | Weight | 350 g | Manufacturer Warranty | 2-year warranty | Designed For | P/N: SVA12M5NA |
General | |
Enclosure Colour | Black |
Chassis | |
Installed Devices / Modules Qty | 0 |
Supported Devices / Modules Qty | 2 |
Storage Controller | |
Type | SATA |
Interface Type | SATA 6Gb/s |
Max Storage Devices Qty | 2 |
Expansion / Connectivity | |
Expansion Bays | 2 (total) / 2 (free) x external - 2.5" / 3.5" shared |
Interfaces | 2 x SATA 6Gb/s - 22 pin Serial ATA |
Miscellaneous | |
Cables Included | 2 x Serial ATA cable |
Compliant Standards | FCC, RoHS |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V - 50/60 Hz |
Dimensions & Weight | |
Width | 13 cm |
Depth | 8 cm |
Height | 3 cm |
Weight | 350 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 20 - 80% |
Compatibility Information | |
