The unmanaged network switch offers five multi-speed Ethernet ports (10/100/1000/2500 Mbps) in a compact and durable all-metal casing while remaining silent and energy-efficient (IEEE 802.3az). The network switch is the ideal solution to dramatically speed up your network to support 2.5GBASE-T, and being an unmanaged switch, you can set it up in no time.
Product Description | StarTech.com Unmanaged 2.5G Switch, 5 Port Gigabit Switch, 2.5GBASE-T Unmanaged Ethernet Switch, Ethernet Splitter, Din Rail or Wall Mount, Multi-Gigabit, All-Metal, Auto-MDIX, 9K Jumbo - 2.5 Gb Network Switch - switch - 5 ports - unmanaged | Device Type | Switch - 5 ports - unmanaged | Subtype | 2.5 Gigabit Ethernet | Ports | 5 x 10/100/1000/2.5G | Max Transfer Distance | 100 m | Jumbo Frame Support | 9KB | Features | Flow control, auto-uplink (auto MDI/MDI-X), full duplex mode, QoS, fanless, EEE, security slot (Kensington security lock compatible) | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az, IEEE 802.3bz | Power | DC 12 V | Dimensions (WxDxH) | 14.5 cm x 12 cm x 3 cm | Weight | 600 g | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop, wall-mountable |
Status Indicators | Power, link/activity |
Expansion / Connectivity | |
Interfaces | 5 x 2.5GBase-T RJ-45 |
Power | |
Power Device | Internal power supply |
Power Provided | 1 A |
Voltage Required | DC 12 V |
Miscellaneous | |
Colour | Black |
Included Accessories | Wall mounting kit |
Compliant Standards | RoHS, WEEE, RCM |
Dimensions & Weight | |
Width | 14.5 cm |
Depth | 12 cm |
Height | 3 cm |
Weight | 600 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 20.7 cm |
Shipping Depth | 14.4 cm |
Shipping Height | 3.8 cm |
Shipping Weight | 700 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 10 - 90% RH |
Min Storage Temperature | -20 °C |
Max Storage Temperature | 60 °C |
