StarTech.com USB 3.0 to 2.5/3.5" SATA HDD / SSD Duplicator Dock - Standalone Hard Drive / HDD Clone
£80.44
16 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • DUPLICATE AND ERASE SATA DRIVES: This 2-bay duplicator and drive eraser features standalone sector-by-sector drive cloning or erasing using Single-Pass Overwrite; Dock your 2.5/3.5" SATA drives for quick access to your files over USB
  • DRIVE COMPATIBILITY: Works with 2.5/3.5" SATA I/II/III HDDs and SSDs of any capacity | 4Kn Support | OS Independent | Includes 3ft (0.9m) USB-A Cable and Universal Power Adapter | IDE adapter (SAT2IDEADP) sold separately
  • DUPLICATION MODES: Standalone sector-by-sector cloning performs whole disk copy including empty sectors. Target disk must be equal/larger than the source disk; Features NIST SP 800-88 Rev 1 (clear) Single-Pass Overwrite
  • SPECS: 2-Bay Hard Drive Duplicator and Eraser Dock | SATA I/II/III | Standalone operation or USB 3.2 Gen 1 (5 Gbps) Host Connection | Toolless/Tray-less Design | Top-Loading w/ Drive Doors & Eject Buttons | Multi-function Power & Status LEDs
  • THE IT PRO'S CHOICE: Designed and built for IT Professionals, this hard drive duplicator dock is backed for 2 years, including free lifetime 24/5 multilingual technical assistance
  • Type: Hard drive Duplicator
  • HD Size: 2.5 / 3.5 shared
  • Power Supply: Power adapter
Product codes
chevron icon
chevron icon
Clone a 2.5in/3.5in SATA drive without a host computer connection, or dock the drives over USB 3.0 for easy access. The SATDOCK2REU3 USB 3.0 Standalone Duplicator and Eraser Dock lets you connect your 2.5in/3.5in SATA HDDs or SSDs through SuperSpeed USB 3.0, with the ability to swap drives in and out as needed. The dock also functions as a standalone drive duplicator and eraser - an efficient and versatile solution for external drive management.
Featuring standalone Sector by Sector hard drive duplication with built-in LED progress bar, and support for 2 drive single pass over writing the SATDOCK22EU3 is a user-friendly all-in-one solution for any application requiring hard drive duplication or erasing.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD/SSD docking station is compatible with virtually any SATA hard drive, and greatly increases the storage/backup capabilities of your computer.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in IDE hard drive into a SATA hard drive dock.
chevron icon
Product Description StarTech.com Dual Bay Hard Drive Duplicator and Eraser, Standalone HDDSSD ClonerCopier, USB 3.0 to SATA Docking Station, Hard Disk Duplicator and Sanitizer Dock - ToollessTop-Loading Design - hard drive duplicator
Device Type Hard drive duplicator
Installed Devices / Modules Qty 0 (installed) / 2 (max)
Supported Drives SATA-300
Storage Controller SATA (SATA 3Gb/s)
Hard Drive No HDD
OS Required Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
Power AC 120/230 V
Dimensions (WxDxH) 10.3 cm x 12.8 cm x 6.2 cm
Weight 424 g
Designed For P/N: SVA12M5NA
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£80.44
