StarTech.com USB 3.1 Adapter Cable w/ USB-C
£21.15
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Get ultra-fast access to data by connecting a 2.5" SATA SSD/HDD to your laptop's USB-C port. Take advantage of the USB-C port on the latest MacBook, Chromebook Pixel or other laptop to get quick external drive access. This cable-style adapter lets you use the USB Type-C port to connect your laptop directly to a 2.5" solid-state or hard drive and access it through ultra-fast USB 3.1 Gen. 2 (10 Gbps). It's fast and easy to connect to your SATA drives, with no additional accessories required.
Use this cable-style adapter, wherever you go, to access valuable data quickly - it's USB powered so there's no external power required. It features a compact, lightweight design that tucks easily into a laptop bag or carrying case.
With the adapter cable, you can quickly swap hard drives without having to install your drives into an enclosure. You can copy or retrieve data from a 2.5" SSD or HDD quickly. It gives you easy drive access for data migration, drive cloning and data backup applications, with the fast performance of USB 3.1 Gen 2.
The integrated, easy-to-use USB Type-C connector is small and reversible, which makes for easier insertions. You can connect the plug with either side facing up, which means less risk of damaging your ports, and less frustration.
USB 3.1 Gen 2 gives you greater bandwidth and speed with file transfer rates of up to 10 Gbps - twice the speed of USB 3.0 (USB 3.1 Gen 1) technology. It lets you leverage the high performance of the latest SSDs and hard drives, while alleviating bottlenecks in your data transfers.
StarTech.com USB 3.1 Gen 2 Adapter Cable for 2.5" SATA Drives - with USB-C - storage controller - SATA 6Gb/s - USB 3.1 (Gen 2)
Storage controller - external
Bus Type
USB 3.1 (Gen 2)
Hard Drive Form Factor Compatibility
2.5", 3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.1 A...
£21.15
