Product Description | StarTech.com USB to Fiber Optic Converter - 1000Base-SX SC - MM - Windows / Mac / Linux - USB 3.0 Ethernet Adapter - Network Adapter (US1GA30SXSC) - network adapter - USB 3.0 - 1000Base-SX | Device Type | Network adapter | Form Factor | External | Interface (Bus) Type | SuperSpeed USB 3.0 | Ports | 1000Base-SX | Dimensions (WxDxH) | 5.5 cm 2 cm | Length | 26 cm | Weight | 100 g | Cabling Type | Ethernet 1000Base-SX | Data Link Protocol | 1GbE | Max Transfer Distance | 550 m | Data Transfer Rate | 1 Gbps | Capacity | Jumbo frame size: 9000 | Compliant Standards | IEEE 802.3z, IEEE 802.1Q | Colour | Black | System Requirements | Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux Kernel 3.5 or later, Apple MacOS X 10.9 - 10.14, Linux LTS versions only, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0 | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Gigabit Ethernet |
Optical Wave Length | 850 nm |
Status Indicators | Power, link/activity |
Features | Full duplex capability, USB powered, Jumbo Frames support |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-SX - SC multi-mode - female |
Miscellaneous | |
Cables Included | 1 x USB cable (integrated) - 19.5 cm |
Compliant Standards | FCC, RoHS, WEEE |
Colour | Black |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux Kernel 3.5 or later, Apple MacOS X 10.9 - 10.14, Linux LTS versions only, Apple macOS 11.0, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 12.0, Apple macOS 13.0 |
Dimensions & Weight | |
Width | 5.5 cm |
Height | 2 cm |
Length | 26 cm |
Weight | 100 g |
Dimensions & Weight (Shipping) | |
Shipping Weight | 120 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 5 - 90% |
