Connect this USB Type-C Multiport Adapter to a USB-C, USB4, or Thunderbolt 3/4 laptop to enable single-display 4K 60Hz HDMI 2.0b or 1080p 60Hz VGA video output via DP Alt Mode. The USB-C dock works with USB Type-C laptops or tablets, such as a Chromebook, Dell XPS, or MacBook. It features a 3-Port USB 3.2 Gen 2 (10Gbps) Hub (2x USB-A, 1x USB-C), and Gigabit Ethernet. Connect the laptop USB-C power supply to the dedicated USB Power Delivery (PD) 3.0 port, to charge the laptop.
Product Description | StarTech.com USB-C Multiport Adapter, HDMI/VGA, 4K 60Hz Video, 3-Port USB Hub, 100W Power Delivery Pass-Through, GbE, USB Type-C Travel Dock w/ Charging, 1ft/30cm Wrap-Around Cable - Mini Laptop Docking Station (DKT31CVHPD3) - docking station - USB-C - VGA, HDMI - 1GbE | Product Type | Docking station | Docking Interface | USB-C | Video Interfaces | VGA, HDMI | Dimensions (WxDxH) | 6.4 cm x 12.4 cm x 2.5 cm | Weight | 130 g | Colour | Space grey | Networking | Gigabit Ethernet | Power | Power adapter 16 Watt Power Provided | Manufacturer Warranty | 3-year warranty |
General | |
Width | 6.4 cm |
Depth | 12.4 cm |
Height | 2.5 cm |
Weight | 130 g |
Enclosure Colour | Space grey |
Video | |
Max Resolution Details | 4096 x 2160 - 60 Hz (HDMI only) , 1920 x 1200 - 60 Hz (VGA only) , 1920 x 1080 - 60 Hz (VGA only) |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | USB 3.2 Gen 2 |
Expansion / Connectivity | |
Interfaces | 1 x display / video - HDMI output - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x USB-C 3.2 Gen 2 - 9 pin USB Type A , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C (power only) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x USB-C 3.2 Gen 2 cable - integrated - 30 cm |
Features | Wake on LAN, Preboot Execution Environment (PXE) support, 2 LED indicators, full duplex support, DisplayPort Alt Mode, plastic housing, 100W power delivery (pass-through), up to 10Gbps data transfer, 84W charging |
Compliant Standards | RoHS, WEEE, RCM, DisplayPort 1.4 |
Power | |
Power Device | Power adapter |
Power Provided | 16 Watt |
System Requirements | |
OS Required | Linux, Android, Google Chrome OS, Ubuntu 18.04, Apple macOS 10.15, Ubuntu 20.04, Apple macOS 12, Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Apple macOS 13.0, Apple macOS 11 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.2 cm |
Shipping Depth | 17 cm |
Shipping Height | 3 cm |
Shipping Weight | 154 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
