This USB-C multiport adapter with DP 1.4 supports 4K 60Hz HDMI (HDR) and turns your MacBook Pro, Dell XPS, or other USB-C laptops or tablet into a workstation, anywhere you go. The USB Type-C multiport adapter provides 4K HDMI video output, two USB 3.1 Gen 2 Type-A (10Gbps) ports, an SD card reader and a Gigabit Ethernet port all through one connection to your laptop's USB-C or Thunderbolt 3/4 port. Plus, it offers advanced charging through USB Power Delivery 3.0 and an extra-long attached 10-inch (25 cm) host cable for an extended reach to offer more set up flexibility. USB 3.1 Gen 2 (10Gbps) is also known as USB 3.1 Gen 2x1 (10Gbps).
Product Description | StarTech.com USB C Multiport Adapter, USB C to 4K 60Hz HDMI 2.0, 2-Port 10Gbps USB Hub, 100W Power Delivery Pass-through, GbE, SD/MicroSD, USB Type-C Mini Dock, 10"/25cm Attached Cable - USB C Docking Station - docking station - USB-C - HDMI | Product Type | Docking station | Docking Interface | USB-C | Video Interfaces | HDMI | Dimensions (WxDxH) | 14.2 cm x 8.2 cm x 2.9 cm | Weight | 150 g | Colour | Space grey | Power | Power Provided | Manufacturer Warranty | 3-year warranty |
General | |
Width | 14.2 cm |
Depth | 8.2 cm |
Height | 2.9 cm |
Weight | 150 g |
Enclosure Colour | Space grey |
Video | |
Max Resolution Details | 4096 x 2160 - 60 Hz |
Networking | |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab |
Expansion / Connectivity | |
Expansion Slots | 1 (total) / 1 (free) x SD / MMC Memory Card |
Interfaces | 2 x USB 3.1 Gen 2 - 9 pin USB Type A , 1 x USB 3.1 Gen 2 with Fast Charging - 24 pin USB-C , 1 x USB-C with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Miscellaneous | |
Input Device | SD card reader |
Cables Included | 1 x USB-C cable - integrated - 25 cm |
Features | Preboot Execution Environment (PXE) support, full duplex support, DisplayPort Alt Mode, plastic housing, Parade PS186 chipset, HDR10 support |
Compliant Standards | FCC, RoHS, WEEE, RCM, DisplayPort 1.2, DisplayPort 1.4, USB Power Delivery 3.0, IEEE 802.3 |
System Requirements | |
OS Required | Google Chrome OS, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Android 9.0 (Pie), Apple macOS Catalina 10.15, Apple iPadOS, Android 10, Apple macOS Big Sur 11.0, Android 11, Apple macOS Monterey 12.0, Windows 8 / 10 / 11, Apple macOS Ventura 13.0 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 21 cm |
Shipping Depth | 14.4 cm |
Shipping Height | 4 cm |
Shipping Weight | 270 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
