7-IN-1 MULTIPORT ADAPTER: Single or Multi Monitor DP 1.4 Alt Mode, HDMI 2.0b, VGA, USB-C port with DP Alt Mode for video or 10Gbps Data, plus 2 x USB-A 3.2 Gen 2 10Gbps hub, 100W USB PD Pass-Through (88W laptop charging), Gigabit Ethernet.
USB-C DOWNSTREAM PORT WITH VIDEO OUTPUT: Industry's first non-Thunderbolt adapter features a 10Gbps USB-C port w/ DP Alt Mode; Connect a portable USB-C monitor or desktop monitor w/USB-C Display Adapter as an extended display, or USB-C peripheral.
FLEXIBLE VIDEO:1x 4K 60Hz HDMI or USB-C DP Alt Mode video, or 2x 4K 30Hz HDMI + USB-C (discrete DP 1.4 GPU) - 1x 4K 30Hz HDMI or USB-C, or 4K 30Hz + 1080p 60Hz in dual monitor (integrated DP 1.4 GPU) - 1x 4K 30Hz HDMI or USB-C, or 2x 1080p (DP 1.2 GPU).
EXTRA LONG CABLE: 10" (25cm) cable for extended reach reducing port/connector strain on 2-in-1 devices like Surface Pro 7/8, iPad Pro, HP Elite X2 or laptops on riser stands; Hideaway cable design stores attached cable during travel.
COMPATIBILITY: Mini dock compatible w/USB-C laptops/Ultrabooks/Chromebooks/Surface/Thunderbolt 3/4/USB4 laptops from HP/Dell/Lenovo; Windows/Android/Linux/ChromeOS - For optimal video performance use with Intel 11th & 12th gen+ laptop CPUs.
CONNECTIVITY TOOLS: Provided with the mobile all-in-one USB Type C docking station adapter this application improves performance and security; Featuring MAC Address Changer, USB Event Monitoring, Windows Layout, and Wi-Fi Auto Switch utilities.
Product Description | StarTech.com USB-C Multiport Adapter with USB-C DP Alt Mode Video Output / 4K HDMI 2.0 / VGA, USB-C Dual Monitor Docking Station, 100W PD Pass-Through, USB Type C Mini Dock/MST Adapter Hub - 2x USB-A 10Gbps, GbE (DKM31C3HVCPD) - docking station - USB-C 3.2 Gen 2 / Thunderbolt 3 / Thunderbolt 4 - VGA, HDMI, USB-C - 1GbE - TAA Compliant | Product Type | Docking station | Docking Interface | USB-C 3.2 Gen 2 / Thunderbolt 3 / Thunderbolt 4 | Video Interfaces | VGA, HDMI, USB-C | Dimensions (WxDxH) | 8.3 cm x 14.4 cm x 2.8 cm | Weight | 168 g | Colour | Space grey | Networking | Gigabit Ethernet | TAA Compliant | Yes | Manufacturer Warranty | 3-year warranty |
General | |
Width | 8.3 cm |
Depth | 14.4 cm |
Height | 2.8 cm |
Weight | 168 g |
Enclosure Colour | Space grey |
Video | |
Max Resolution Details | 3840 x 2160 - 60 Hz (HDMI only) , 3840 x 2160 - 60 Hz (DisplayPort 1.4 over USB-C) , 3840 x 2160 - 30 Hz (HDMI and DisplayPort 1.4 over USB-C simultaneously) , 1920 x 1200 - 60 Hz (VGA only) |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Compliant Standards | USB 3.2 Gen 2 |
Expansion / Connectivity | |
Interfaces | 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x USB-C 3.2 Gen 2/DisplayPort - 24 pin USB-C , 2 x USB 3.2 Gen 2 - 9 pin USB Type A , 1 x USB-C with Power Delivery (100 W) - 24 pin USB-C (power only) , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x USB-C 3.2 Gen 2 cable - integrated - 25 cm |
Features | Wake on LAN, full duplex support, MST (multi-stream transport), plastic housing, USB-C Alt Mode, HDR10 support, 100W power delivery (pass-through) |
Compliant Standards | FCC, RoHS, WEEE, DisplayPort 1.4, UASP (USB Attached SCSI Protocol), USB Power Delivery 3.0 |
System Requirements | |
OS Required | Linux, Android, Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10 / 11 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.4 cm |
Shipping Depth | 20.7 cm |
Shipping Height | 3.8 cm |
Shipping Weight | 258 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
