Use this adapter to connect two independent displays to a single USB Type-C port. This MST hub lets you connect two DisplayPort monitors to your USB-C computer. MST works on any Windows device with DP alt mode over USB Type-C, such as models of Dell Precision and Dell XPS laptops. The MST hub is powered by the USB-C port, so you don't require an additional power adapter.
This adapter works with USB Type-C devices that pass a DisplayPort video signal and it's also compatible with Thunderbolt 3 ports.
The newest generations of laptops are more portable than ever. Unfortunately, this could mean that you're left with fewer video outputs and confined to a small integrated screen. This MST hub solves these problems by letting you connect two independent displays to a USB-C port on your computer, which makes multitasking much easier.
Using the MST hub, you can extend your desktop onto additional monitors and stream independent content to each display. This makes it easier to multitask and increase your productivity - perfect for creating an easy-to-dock hot-desk solution with a wireless keyboard and mouse peripheral set.
The hub also lets you mirror the same image onto multiple displays, for remote viewing applications such as digital signage.
MST technology uses your existing video card to minimize the use of system resources while delivering Ultra HD 4K resolutions. 4K is supported by the latest A/V devices and offers four times the resolution of 1080p. Plus, because the MST hub can output high-definition 1080p, the MST hub is perfect for all high-resolution applications such as graphic design and CAD drawing.
With this MST hub, you can use separate DP video adapters to connect HDMI, VGA or DVI displays, for compatibility with all of your existing monitors. The hub supports DP 1.2 enabled systems, for seamless integration with your existing video equipment.
Product Description | StarTech.com 2-Port Multi Monitor Adapter, USB-C to 2x DisplayPort 1.2 Video Splitter, USB Type-C to DP MST Hub, Dual 4K 30Hz or 1080p 60Hz, Compatible with Thunderbolt 3, Windows Only - Multi Stream Transport (MSTCDP122DP) - DisplayPort adapter - 24 pin USB-C to DisplayPort - 38.6 m | Type | DisplayPort adapter | Features | USB power, 4K30Hz (3840 x 2160) support, 2560 x 1600 (WQXGA) support 60Hz, HBR2 support, DisplayPort Alternate Mode support, DisplayPort Multi-Stream Transport (MST), 5.1 audio channel support | Length | 38.6 m | Connector | 24 pin USB-C - male (input) | Connector (Second End) | 2 x 20 pin DisplayPort - female (output) | Compliant Standards | Displayport 1.2/Thunderbolt 3 | Colour | Black | Manufacturer Warranty | 3-year warranty | Designed For | P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, TB33A1C |
