This USB duplicator and eraser lets you clone or erase up to 15 USB flash drives, without a host computer connection. This means you can work more efficiently and manage larger batches of USB drives, saving time and effort.
The standalone USB duplicator and eraser is perfect for IT professionals and system administrators in corporate, education, marketing, or sales environments.
Product Description | StarTech.com Standalone USB Duplicator - USB Duplicator and Eraser - USB 3.0, 2.0, 1.1 - 1:15 USB Flashdrive - USB Thumb Drive (USBDUPE115) - USB drive duplicator - TAA Compliant | Device Type | USB drive duplicator | Colour | Black | Max Supported Capacity | 2 TB | Installed Devices / Modules Qty | 15 (max) | Duplication Speed | 1.5 GBpm | Localisation | Australia, Japan, New Zealand, North America, United Kingdom, Europe | Built-in Devices | Status LCD | Power | AC 120/230 V | TAA Compliant | Yes | Dimensions (WxDxH) | 34.5 cm x 16 cm x 3.46 cm | Weight | 1.8 kg | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Colour | Black |
Chassis | |
Supported Devices / Modules Qty | 15 |
Storage | |
Expansion / Connectivity | |
Interfaces | 16 x USB 2.0 - 4 pin USB Type A |
Miscellaneous | |
Features | Xilinx Spartan XC3S700A chipset, buffer 128 MB, 16 LED indicators |
MTBF | 8760 hours |
Compliant Standards | FCC, RoHS, WEEE, RCM |
Power | |
Power Device | 1 x external power adapter |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 150 Watt |
Dimensions & Weight | |
Width | 34.5 cm |
Depth | 16 cm |
Height | 3.46 cm |
Weight | 1.8 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 45 °C |
Humidity Range Operating | 20 - 80% |
