Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
StarTech.com USB to VGA External Video Card Multi Monitor Adapter – 1920x1200
£25.36
23 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • Compact, USB-powered adapter provides the easiest way add secondary or multiple high-resolution displays to your PC
  • Completely external device offers a simple upgrade solution saving the cost and hassle of upgrading the internal video card on your system
  • The ability to use multiple adapters (up to five) provides a scalable display configuration for future expansion
Product codes
chevron icon
chevron icon
The USB2VGAE3 USB VGA Multi-Monitor External Video Adapter lets you add a high-resolution (1920x1200) external VGA output to your desktop or laptop computer, using an available USB 2.0 port. A cost-effective solution for systems that lack the outputs required for a multi-monitor setup, this high-performance USB to VGA adapter can be used to mirror your primary display and show the same image on both screens, or extend your desktop to double your workspace. This small form factor USB video adapter can be used with up to 4 additional (5 total) USB2VGAE3 USB video adapters, creating multiple VGA connections to add displays quickly and easily - all without having to open the computer case to add extra video cards.
chevron icon
Product Description StarTech.com USB to VGA Adapter - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB2VGAE3) - USB / VGA adapter - USB to HD-15 (VGA) - TAA Compliant - 50 cm
Type USB / VGA adapter
Features 1920 x 1200 (WUXGA) support, 32 MB memory
Length 50 cm
Connector 4 pin USB Type A - male (input)
Connector (Second End) 15 pin HD D-Sub (HD-15) - female (output)
Compliant Standards USB / USB 2.0
Colour Grey
TAA Compliant Yes
Designed For P/N: MXT101MM
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£25.36
