ITEM | QTY | PRICE |
Kingston 32GB USB 3.0 DT4000 G2 256 A...
4 | £546.00 |
The USB2VGAE2 USB to VGA external video adapter is the perfect multi-monitor VGA solution for office applications and Internet browsing.
The USB video adapter features a small form factor and enables a USB 2.0 port to be used with a VGA port. A cost-saving multi-monitor or dual display option that can be used as an external graphics card for either laptop or desktop applications.
The USB video adapter can be used with up to four additional (five total) USB2VGAE2 USB video adapters, creating multiple VGA connections that can be used to further extend or mirror the desktop shown on the existing display - all without having to open the computer case to add extra video cards.
Product Description | StarTech.com USB to VGA Adapter - 1440x900 - adapter - VGA / USB - TAA Compliant - 7.5 cm | Cable | Adapter - VGA / USB | TAA Compliant | Yes | Max Output Resolution | 1600 x 1200 | Length | 7.5 cm | Colour | Grey | Connector | USB - male (input) | Connector (Second End) | HD-15 (VGA) - female (output) | Compliant Standards | USB / USB 2.0 | Manufacturer Warranty | 2-year warranty | Designed For | P/N: MXT101MM |
General | |
Cable Type | Adapter |
Interface Supported | VGA / USB |
Jacket Material | Plastic |
Length | 7.5 cm |
Colour | Grey |
Adapters & Converters | |
OS Required | Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 |
Connectivity | |
Connector | 4 pin USB Type A - male (input) |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female (output) |
Miscellaneous | |
Compliant Standards | FCC, RoHS, WEEE, REACH, RCM |
Dimensions & Weight | |
Width | 4.2 cm |
Height | 5 cm |
Weight | 80 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 14.8 cm |
Shipping Depth | 21 cm |
Shipping Height | 4 cm |
Shipping Weight | 235 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
