StarTech.com Vertical Dual Monitor Stand
£140.48
Delivery:
Standard: 1-3 working days
Key features
  • Vertical dual-monitor stand supports two displays up to 27" each (max weight 17.6 lb. (8 kg) per monitor)
  • The height of the monitors can be adjusted along the 28" (710 mm) pole
  • Adjust your screen angle easily with +15°/-15° tilt and +15°/-15° swivel
  • Accessory Type: Stand , Monitor Stand
Product codes
chevron icon
chevron icon
This vertical dual-monitor stand, with its sleek aluminum design, raises two displays off the surface of your desk or table, to save space while increasing your productivity. With its robust construction, the freestanding dual-monitor mount securely holds two VESA mount monitors, each up to 27", stacked vertically.
The dual-monitor mount holds two displays, one above the other. You can adjust the height of the monitors along the 28" (710 mm) pole, to work in comfort with your two-monitor setup.
The adjustable monitor stand for desks enables smooth, effortless +15/-15 degree tilt and swivel, making it easy to find the perfect viewing angle. It can also rotate a full 360 degrees, giving you the flexibility of portrait or landscape viewing.
The dual-monitor stand securely holds your monitors in place while complimenting your office decor with its black and silver aluminum design. The monitor stand supports two monitors, each up to 27" (686 mm) in size and 17.6 lb. (8 kg) in weight.
The VESA monitor stand is easy to install, featuring quick monitor attachment and removal. It also provides cable management to keep your cables neatly out of sight.
chevron icon
Product Description StarTech.com Vertical Dual Monitor Stand, Ergonomic Desktop Stacked Two Monitor Stand up to 27 inch VESA Mount Displays, Free Standing Universal Monitor Mount, Height Adjustable, Silver - Double Monitor Holder (ARMDUOVS) stand - for 2 monitors - black, silver
Product Type Stand - desktop stand
Dimensions (WxDxH) 11.5 cm x 16 cm x 94 cm
Tilt -15° to 15°
Rotation 360°
Swivel -15° to 15°
Adjustments Height, tilt, swivel, rotation
Weight 4.2 kg
Recommended Use 2 monitors
Recommended Display Size 13"-27"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm
Max Load Weight 8 kg
Material Plastic, aluminium
Colour Black, silver
Package Content 2 x VESA monitor mounts, 8 x M4x30 screws, hex key (4mm), hex key (3mm), 8 x washers, 16 x spacers, lower pole, base, 8 x M4x14 screws, 8 x M5x14 screws, upper pole, pole connector, 2 x cable management hooks, 3 mm hex key with screwdriver tip, 2 x cable management hook screws, 8 x M5x30 screws
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£140.48
