Product Description | StarTech.com VESA Mount Adapter for Tablets 7.9 to 12.5in - Up to 2kg (4.4lb) - 75x75/100x100 VESA Patterns - Universal Anti-Theft Tablet VESA Mount Clamp - Secure Tablet Mount - Black - mounting kit - for tablet - black | Product Type | Mounting kit - arm mountable, stand mountable, VESA bracket mounting - lockable | Mounting Components | Tablet security holder, weighted plate | Dimensions (WxDxH) | 23.7 cm x 16.1 cm x 4.1 cm | Adjustments | Height, tilt, rotation | Weight | 600 g | Recommended Use | Tablet | Recommended Display Size | 7.9" - 12.5" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm | Max Load Weight | 2 kg | Material | Plastic, steel | Colour | Black | Package Content | 2 keys, 4 x washers, 4 x M4x10 screws, 4 x M4x8 screws, star bit tool | Manufacturer Warranty | 5-year warranty | Designed For | Apple 11-inch iPad Pro (1st generation, 2nd generation, 3rd generation) |
General | |
Width | 23.7 cm |
Depth | 16.1 cm |
Height | 4.1 cm |
Weight | 600 g |
Colour | Black |
AV Furniture | |
Type | Mounting kit |
Placing / Mounting | Arm mountable, stand mountable, VESA bracket mounting |
Lockable | Yes |
Dimensions & Weight Details | |
Shipping Dimensions (WxDxH) / Weight | 25.5 cm x 17.5 cm x 4.5 cm / 800 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
