DS1618+ is a 6-bay NAS that provides storage scalability perfect for tech enthusiasts and small- to medium-sized businesses by effortlessly handling workloads.
Product Description | Synology Disk Station DS1618+ - NAS server - 6 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 6 TB | Max Supported Capacity | 72 TB | Installed Devices / Modules Qty | 6 (installed) / 6 (max) | Dimensions (WxDxH) | 28.2 cm x 24.3 cm x 16.6 cm | Weight | ) | Processor | 1 x Intel Atom C3538 2.1 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 6 x 1 TB | Networking | 10Mb LAN, 100Mb LAN, 1GbE | IP Cameras Supported | 40 | RAM | 4 GB | Power | AC 120/230 V (50/60 Hz) | System Requirements | Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 28.2 cm |
Depth | 24.3 cm |
Height | 16.6 cm |
Weight | ) |
Built-in Devices | Led panel |
Processor / Memory | |
Processors Installed | 1 x Intel Atom C3538 2.1 GHz |
Number of Cores | Quad-Core |
RAM | 4 GB (installed) / 32 GB (supported) - DDR4 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD - hot-swap |
Capacity | 6 x 1 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE |
Network / Transport Protocol | TCP/IP, PPTP, L2TP, iSCSI, FTP, SMB, SFTP |
Remote Management Protocol | SNMP, Telnet, HTTP, HTTPS, TFTP, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV) |
Features | Hardware encryption, VPN support, wake on LAN (WOL), Syslog support, High Availability, download client, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, surveillance station, PXE support, DLNA Media Server, Apple Time Machine compatible, WebDAV server, VPN Server, anti-virus protection, Link Aggregation, failover protection, DLNA support, OpenStack compatible, SSD trim, iSCSI LUN clone/snapshot, Windows ODX, cloud station server, MailPlus server, Rsync compatible, Synology Hybrid RAID |
Encryption Algorithm | SSL, TLS, AES-NI |
Compliant Standards | DLNA CERTIFIED |
Security DVR | |
Compression Format | MJPEG, H.264, H.265 |
Image Resolution | 1280x720, 1920x1080, 2048x1536, 2591x1944, 3840x2160 |
Expansion / Connectivity | |
Expansion Bays | 6 (total) / 0 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 1 x PCI Express 3.0 x8 |
Interfaces | 3 x USB 3.0 , 4 x Ethernet 1000Base-T - RJ-45 , 2 x eSATA |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), wake on LAN, built-in 2 cooling fans, Citrix Ready, VMware Ready |
Security Slot Type | Kensington security slot |
Compliant Standards | VCCI, BSMI, CCC, FCC, RoHS, EAC, RCM |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 56.86 Watt |
Power Consumption Stand by | 25.76 Watt |
Power Provided | 250 Watt |
Software / System Requirements | |
Software Included | McAfee AntiVirus (Trial) |
OS Required | Apple MacOS X 10.11 or later, Microsoft Windows 7 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% |
Sound Emission | 23.7 dBA |
