tado Add-on Smart Radiator Thermostat
FREE DELIVERY
Single Pack
£69.99
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for communal heating
  • Save up to 31% on your heating bills!
  • 2 Years Warranty
  • Type: Smart radiator valve
  • Compatible With: Alexa, Google Assistant
Product codes
To independently control your rooms with radiators, you can supplement your Starter Kit with extra Smart Radiator Thermostats.
The smart way to control your heating in individual rooms
Never heat your whole home again! tado° Smart Radiator Thermostats can replace your existing thermostatic radiator valves and provide room-by-room scheduling and control, so you can enjoy greater comfort and improve the efficiency of your heating system.
To benefit from tado° Smart Radiator Thermostats, you must also install a tado° Starter Kit.
Easy to install
This product can be easily self-installed - simply unscrew your existing thermostatic radiator valve, replace this with a tado° Smart Radiator Thermostat (using one of the 6 adaptors provided if required), and add the device in your tado° app.
Easy to use
The highly rated tado° app enables you to individually schedule and control each Smart Radiator Thermostat from anywhere, as well as providing insights and reports about the climate of individual rooms and showing you the energy savings made by tado°.
tado° is also compatible with Amazon Alexa, Apple HomeKit and Google Assistant, meaning you can control your heating in each room where you have a Smart Radiator Thermostat, using your voice, as well as integrating them into routines with your other smart home devices.
tado° comes with an Energy Savings Guarantee - if you are not satisfied that tado° has saved you energy in the first 12 months, simply return the product to tado° and get your money back, no questions asked!
Adaptable
For more efficient heating, tado° uses the local weather forecast in real time to control your heating. For example, it will heat less on a sunny day.
Tado° learns how fast it takes for your home to heat up and cool down to ensure your heating always starts at the right time.
Save money by not heating an empty home - tado° uses geofencing technology to adapt your heating. By using your location, it can start heating up when someone heads home, and turn down when the last person leaves.
You can add up to 25 devices to your tado° Home and up to 100 users can be added to your tado° Home
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£69.99
