tado Smart Radiator Thermostats - 4 Pack
FREE DELIVERY
LIMITED TIME OFFER
USUALLY £249!
4 Pack
£199.00
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Ideal for communal heating
  • More comfort
  • Save up to 31% on your heating bills!
  • Type: Smart radiator valve
  • Compatible With: Alexa, Google Assistant
Product codes
Bundle deals (1)
BUY MORE AND SAVE!
BUY MORE AND SAVE!
= £369.00
Save £29.00
To independently control your rooms with radiators, you can supplement your Starter Kit with extra Smart Radiator Thermostats.
The smart way to control your heating in individual rooms
Never heat your whole home again! tado° Smart Radiator Thermostats can replace your existing thermostatic radiator valves and provide room-by-room scheduling and control, so you can enjoy greater comfort and improve the efficiency of your heating system.
To benefit from tado° Smart Radiator Thermostats, you must also install a tado° Starter Kit.
Easy to install
This product can be easily self-installed - simply unscrew your existing thermostatic radiator valve, replace this with a tado° Smart Radiator Thermostat (using one of the 6 adaptors provided if required), and add the device in your tado° app.
Easy to use
The highly rated tado° app enables you to individually schedule and control each Smart Radiator Thermostat from anywhere, as well as providing insights and reports about the climate of individual rooms and showing you the energy savings made by tado°.
tado° is also compatible with Amazon Alexa, Apple HomeKit and Google Assistant, meaning you can control your heating in each room where you have a Smart Radiator Thermostat, using your voice, as well as integrating them into routines with your other smart home devices.
tado° comes with an Energy Savings Guarantee - if you are not satisfied that tado° has saved you energy in the first 12 months, simply return the product to tado° and get your money back, no questions asked!
Smart Skills
Tado° takes local weather forecasts into account. It turns down the heating, if the sun is warming up your home, to save energy. Along side the Air Comfort Skill, tado° advises you on how to keep the air in your home healthy. It also gives you insights about the outdoor air quality. With the Smart Schedule, tado° lets you plan your desired day and night time temperatures in time blocks based on your routine. Geofencing reminds you to turn down the heating when the last person leaves home, turn it up in time for the first person’s arrival and detects open windows and reminds you to turn down your heating to save more energy.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£199.00
