We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Toshiba's Canvio Basics for the PC requires only a single step to start saving and transporting important files, plug it in. With no software necessary to install, the Canvio Basics portable hard drive offers a hassle-free, high capacity storage solution right out of the box.
A sleek solution with plenty of storage capacity for the growing amount of digital content, from photos and videos to music and documents, the Canvio Basics offers an intelligent combination of data protection, portability, and simplicity. The one plug ease-of-use is complemented by the drive's stylish design, courtesy of a glossy finish and soft, rounded edges. Despite its light weight design and diminutive size, the Canvio Basics can add peace of mind by keeping files safe with its internal shock sensor and Ramp Loading technology.
Beyond its technical capabilities, the practicality of the Canvio Basics portable hard drive is evident in the drive's pocket-sized form factor which not only makes it easy to carry but also conforms to Toshiba's environmental efforts to reduce materials used in production. In addition, the Canvio Basics' packaging is made from 100 percent recyclable materials.
Product Description | Toshiba Canvio Basics - hard drive - 500 GB - USB 3.0 | Type | Hard drive - external (portable) | Capacity | 500 GB | Interface | USB 3.0 | Data Transfer Rate | 5.0 Gbps (USB 3.0) | Features | NTFS formatted, LED power indicator | Power Source | USB bus | Enclosure Colour | Black | Dimensions (WxDxH) | 78 mm x 109 mm x 14 mm | Weight | 140 g | Manufacturer Warranty | 2-year warranty |
General | |
Device Type | Hard drive - external (portable) |
Capacity | 500 GB |
Width | 78 mm |
Depth | 109 mm |
Height | 14 mm |
Weight | 140 g |
Performance | |
Interface Transfer Rate | 5.0 Gbps (USB 3.0) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.0 - 10 pin Micro-USB Type B |
Power | |
Software & System Requirements | |
OS Required | Microsoft Windows 7 / 8.1 / 10 |
Miscellaneous | |
Cables Included | 1 x USB cable - USB Type A to micro-B - external |
Compliant Standards | Plug and Play |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
