Marketing description is not available.
Product Description | Toshiba Satellite Pro A50-C-23P - 15.6" - Core i5 6200U - 4 GB RAM - 500 GB HDD | Product Type | Notebook | Processor | Intel Core i5 (6th Gen) 6200U / 2.3 GHz (2.8 GHz) / 3 MB Cache | Memory | 4 GB DDR3L | Storage | 500 GB HDD / 7200 rpm | Display | 15.6" LED backlight / HD | Graphics | Intel HD Graphics 520 | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Gigabit Ethernet | Battery | 4-cell | Features | Accelerometer | Security | Trusted Platform Module (TPM 2.0) Security Chip | Dimensions (WxDxH) | 37.9 cm x 25.8 cm x 2.395 cm | Weight | 2.1 kg | Localisation | United Kingdom | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1 year warranty |
General | |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD / 7200 rpm |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HighBrightness |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes |
Resolution | 2 Megapixel |
Sound | Stereo speakers |
Compliant Standards | DTS Sound |
Input | |
Type | Keyboard, touchpad |
Features | Palm Rejection Technology |
Communications | |
Wireless | 802.11a/b/g/n/ac |
Wireless Controller | Intel Dual Band Wireless-AC 8260 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell Lithium Ion |
AC Adapter | |
Output | 19 V |
Connections & Expansion | |
Memory Card Reader | Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card) |
Miscellaneous | |
Integrated Options | Accelerometer |
Features | Administrator password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Included Accessories | Power adapter |
Localization | United Kingdom |
Dimensions & Weight | |
Weight | 2.1 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | 1 year warranty |
