When you hold a lot of responsibility, you need a laptop that puts you in control. So like all Z-series devices, the Tecra Z50-C delivers the features you need to stay productive. When you're working into the evening, you can rely on the backlit keyboard to make typing comfortable. When you're reviewing large amounts of data, you can benefit from the matte, high-brightness Full HD display to make you more productive. And when you're typing up notes in a meeting, you can remain discreet thanks to the durable, silent keys. What's more, the Tecra Z50-C's integrated ClickPad and Accupoint allow you to navigate almost any task, in the way that works for you.
Product Description | Dynabook Toshiba Tecra Z50-C-151 - 15.6" - Intel Core i5 - 6200U - 4 GB RAM - 128 GB SSD - 4G LTE | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (6th Gen) - 6200U / 2.3 GHz, up to 2.8 GHz / 3 MB Cache | Memory | 4 GB DDR3L (1 x 4 GB) | Storage | 128 GB SSD | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 520 | Input Device | DualPoint, ClickPad | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1, Gigabit Ethernet | Wireless Broadband (WWAN) | 4G LTE | Battery | 4-cell - up to 8 hours | Features | Accelerometer | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader | Colour | Steel grey hairline, tile black (keyboard) | Dimensions (WxDxH) | 37.9 cm x 25.8 cm x 2.325 cm | Weight | 2 kg | Localisation | Region: United Kingdom | Environmental Standards | - ENERGY STAR Qualified EPEAT Climate+ | Manufacturer Warranty | EMEA warranty - 1 year - carry-in |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (6th Gen) 6200U / 2.3 GHz |
Max Turbo Speed | 2.8 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 128 GB SSD |
Display | |
Type | 15.6" - IPS |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | HighBrightness, anti-reflective, Wide Viewing Angle |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Camera | Yes - Full HD |
Resolution | 2 Megapixel |
Sound | Stereo speakers, two microphones |
Compliant Standards | DTS Studio Sound |
Input | |
Type | Keyboard, DualPoint, ClickPad |
Features | Multi-touch clickpad, gesture function |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Wireless Controller | Intel Dual Band Wireless-AC 8260 |
Network Interface | Gigabit Ethernet |
Features | Intel Wireless Display (WiDi) |
Compliant Standards | Wi-Fi CERTIFIED |
Wireless Broadband (WWAN) | |
Generation | 4G |
Technology | GSM, GPRS, EDGE, HSPA+, LTE |
Controller | Sierra Wireless AirPrime EM7305 |
Navigation | |
Receiver | A-GPS |
Battery | |
Technology | 4-cell Lithium Ion |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V |
Output | 19 V, 2.37 A |
Connections & Expansion | |
Interfaces Details | VGA , LAN , Headphone/microphone combo jack , 3 x USB 3.0 , HDMI , Dock , USB 3.0 (Sleep & Charge) |
Memory Card Reader | Yes (SD Card, MultiMediaCard, SDHC Card, SDXC UHS Card) |
Software | |
Software Included | Toshiba PC Health Monitor, Toshiba Eco Utility, Microsoft 365 (30 days trial), DTS Sound, McAfee LiveSafe (30 days subscription) |
Miscellaneous | |
Integrated Options | Accelerometer |
Dockable | Yes |
Features | Administrator password, system password, hard drive password, Intel Active Management Technology (iAMT) |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | TUV Rheinland |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2 kg |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | EMEA warranty - 1 year - carry-in |
