The TXM431-LR is designed to extend transfer distance based on 10Gbps Ethernet connectivity. It is a 10GBASE-LR high performance 1310nm single-mode SFP+ transceiver. It supports full duplex, and 10G Ethernet connections up to 10km with 9/125µm fiber cables.
Product Description | TP-Link TXM431-LR - SFP+ transceiver module - 10GbE | Device Type | SFP+ transceiver module - LC single-mode | Form Factor | Plug-in module | Cabling Type | 10GBase-LR | Data Transfer Rate | 10 Gbps | Optical Wave Length | 1310 nm | Data Link Protocol | 10GbE | Max Transfer Distance | 10 km |
General | |
Device Type | SFP+ transceiver module |
Networking | |
Connectivity Technology | Wired |
Features | Full duplex capability |
Compliant Standards | IEEE 802.3ae |
Expansion / Connectivity | |
Interfaces | 1 x Ethernet 10GBase-LR - LC single-mode female x 2 |
Miscellaneous | |
Compliant Standards | FCC |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
