TP-Link's new TL-SL1218MP PoE switch with all 16 ports supporting the PoE+ standard provides a simple way to expand the wired network while transferring power over the same Ethernet cable at the same time. With a total power budget of 192W, up to 30W per port, TL-SL1218MP can power more high-powered devices such as Access Points, IP Cameras, IP Phones and so on. Moreover, with innovative Extend Mode, devices can get PoE power supply and data transmission from 250m's distance. Priority mode ensures high priority for Port 1-8, which guarantees the quality of sensitive applications.
Product Description | TP-Link TL-SL1218MP - switch - 16 ports - unmanaged - rack-mountable | Device Type | Switch - 16 ports - unmanaged | Enclosure Type | Rack-mountable | Subtype | Fast Ethernet | Ports | 16 x 10/100 (PoE+) + 2 x 10/100/1000 + 2 x combo Gigabit SFP | PoE Budget | 192 W | Performance | Switching capacity: 7.2 Gbps , Packet forwarding rate: 5.36 Mpps | MAC Address Table Size | 8K entries | Jumbo Frame Support | 10KB | Features | Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 44 cm x 18 cm x 4.4 cm | Manufacturer Warranty | Limited lifetime warranty |
General | |
Status Indicators | Power, 100M device connected, link/activity |
Expansion / Connectivity | |
Interfaces | 16 x 100Base-TX RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 217.22 Watt |
Miscellaneous | |
Rack Mounting Kit | Included |
Compliant Standards | Plug and Play, FCC Class A certified, EN 60950, EN55022, EN55024, FCC Part 15 |
Dimensions & Weight | |
Width | 44 cm |
Depth | 18 cm |
Height | 4.4 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
