TP LINK 300Mbps Universal Wireless N Range Extender
£17.94
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Range Extender mode boosts wireless signal to previously unreachable or hard-to-wire areas flawlessly
  • Miniature size and wall-mounted design make it easy to deploy and move flexibly
  • Easily expand wireless coverage at a push of Range Extender button
  • Smart signal indicator light help to find the right location to place the range extender
  • Ethernet port allows the Extender to function as a wireless adapter to connect wired devices
  • 300 Mbps wireless data rates ideal for video streaming, online gaming and Internet calling
  • Type: Wi-Fi range extender
  • Connectivity: Wireless, Wired
  • Speed: 300Mbps, < 1000 Mbps
  • Protocol: IEEE 802.11g, IEEE 802.11n, IEEE 802.11b, Fast Ethernet + 5 more
  • Compatibility: Mac, PC
Product codes
chevron icon
chevron icon
TP-LINK's TL-WA850RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones". With 300Mbps wireless N speeds, Range Extender button, miniature size and wall mounting design, extending a wireless network has never been easier. What's more, its Ethernet port allows the TL-WA850RE to act as a wireless adapter to turn a wired device into a wireless one.
The TL-WA850RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones", help users maintain an existing wireless network and vastly improve the network's coverage. With 300Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
The device's miniature size and wall-mounted design make it easy to deploy and move flexibly. What's more, the TL-WA850RE's profile function remembers previously paired wireless networks, meaning there is no need to reset the device when changing the paired router.
With no new wires or cables, within range of their existing wireless network, users can easily extend wireless coverage at a push of the WPS button on their router followed by the Range Extender button on the TL-WA850RE or vice versa. An additional push of the pair button can quickly establish an encrypted connection with client devices.
The TL-WA850RE's single Ethernet port allows the Extender to function as a wireless adapter to connect wired devices like Blu-ray® players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
5 signal lights represent the current signal strength that TL-WA850RE receives from existing router, which can help to find the right location to place the range extender so that the TL-WA850RE can achieve the best possible range and performance of the network.
Works seamlessly with all 802.11 b/g/n wireless devices. It is also compatible with the latest Windows 8 operating system.
chevron icon
Product Description TP-Link TL-WA850RE 300Mbps Universal Wireless N Range Extender - Wi-Fi range extender - Wi-Fi
Device Type Wi-Fi range extender
Form Factor External
Localisation United Kingdom
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band 2.4 GHz
OS Required UNIX, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7, Windows 8
Dimensions (WxDxH) 11 cm x 6.58 cm x 7.52 cm
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£17.94
