TP LINK Archer MR200 AC750 Wireless Dual Band 4G LTE Router
£103.87
45 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Shares your 4G LTE network with multiple Wi-Fi devices and enjoy download speeds of up to 150 Mbps
  • Powerful, integrated antennas provide stable wireless connections and better coverage
  • Requires no configuration, just insert a SIM card and turn it on to enjoy a fast wireless connection
  • Creates simultaneous dual band Wi-Fi networks
  • Type: Wireless router
  • Standards: Ethernet, Fast Ethernet, IEEE 802.11a, IEEE 802.11ac + 3 more
  • Speed: 433Mbps
  • Stock Status: In Stock
Product codes
Take full advantage of your cutting-edge 4G LTE network with the Archer MR200, which can achieve download speeds of up to 150 Mbps. The Archer MR200 allows you to share your 4G LTE network with multiple Wi-Fi devices so you can enjoy uninterrupted HD movies, rapid file downloads, and video chats that won't freeze up.
The 4G LTE router creates a simultaneous dual band Wi-Fi network that can deliver data at speeds of up to 733 Mbps. The two distinct wireless networks, utilizing the 2.4 GHz and 5 GHz bands, provide optimized performance and minimize signal interference. The incorporation of advanced antennas and the latest wireless technology allows you to enjoy stable connections and incredible coverage.
With an integrated 4G LTE modem and a built-in SIM card slot, all you need to do insert a SIM card and turn on the Archer MR200. Enjoying fast, stable Wi-Fi on a 4G LTE network has never been easier.
Product Description TP-Link Archer MR200 - wireless router - WWAN - 802.11a/b/g/n/ac - desktop
Device Type Wireless router - wireless cellular modem - 3-port switch (integrated)
Enclosure Type Desktop
Cellular Protocol GSM, GPRS, UMTS, EDGE, HSPA, HSPA+, LTE, DC-HSPA+
WAN Ports Qty 1
Data Link Protocol Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band 2.4 GHz / 5 GHz
Data Transfer Rate 433 Mbps
Capacity IPSec VPN tunnels: 10
Network / Transport Protocol TCP/IP, PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DDNS
Routing Protocol Static IP routing
Remote Management Protocol SNMP 1, Telnet, SNMP 2c, HTTP, CLI
Features Firewall protection, DHCP support, NAT support, NAPT support, IGMP snooping, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, parental control, IP address filtering, firmware upgradable, Quality of Service (QoS)
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac
Dimensions (WxDxH) 20.2 cm x 14.1 cm x 3.36 cm
System Requirements Apple MacOS, Microsoft Windows 98SE/2000/NT/XP/Vista/7, Windows 8 / 8.1
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK Archer MR200 A...
£103.87
