Integrating advanced HomePlug AV2 technology, this kit provides users with high-speed data transfer rates up to 1000 Mbps, which is ideal for bandwidth-intensive applications such as simultaneous HD/3D/4K video streaming, online gaming, and large file transfers. Just plug in and enjoy!
Product Description | TP-Link TL-PA7027P V1 Starter Kit - powerline adapter kit - wall-pluggable | Device Type | Powerline adapter kit | Enclosure Type | Wall-pluggable | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, HomePlug AV (HPAV), HomePlug AV (HPAV) 2.0, IEEE 1901 | Data Transfer Rate | 1000 Mbps | Features | Power-saving mode, pair button | Compliant Standards | IEEE 802.3, IEEE 802.3u, HomePlug AV, HomePlug AV 2.0, IEEE 1901 | Dimensions (WxDxH) | 5.8 cm x 4.2 cm x 9.5 cm | Weight | 320 g | System Requirements | Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 | Manufacturer Warranty | 3-year warranty |
General | |
Connectivity Technology | Wired |
Max Range Indoors | 300 m |
Encryption Algorithm | 128-bit AES |
Compliant Standards | IEEE 802.3, IEEE 802.3u, HomePlug AV, HomePlug AV 2.0, IEEE 1901, Plug and Play |
Built-in Devices | Power outlet |
Status Indicators | Power, Internet, powerline |
Line Properties | |
Line Coding Format | OFDM |
Expansion / Connectivity | |
Interfaces | 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0 |
Power | |
Power Device | Internal power supply |
Power Consumption Operational | 4 Watt |
Miscellaneous | |
Cables Included | 2 x network cable |
Software / System Requirements | |
OS Required | Apple MacOS, Linux, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10 |
Dimensions & Weight | |
Width | 5.8 cm |
Depth | 4.2 cm |
Height | 9.5 cm |
Weight | 320 g |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
