ITEM | QTY | PRICE |
C2G 5m USB 2.0 A/B Cable - Black
4 | £27.52 |
Philips E-line 242E1GAEZ 24" 192...
4 | £605.68 |
HP EliteBook 630 G9 Intel Core i5-123...
3 | £3,091.77 |
Deco uses a system of units to achieve seamless whole-home Wi-Fi coverage - eliminate weak signal areas once and for all! With advanced Deco Mesh Technology, units work together to form a unified network with a single network name. Devices automatically switch between Decos as you move through your home for the fastest possible speeds.
A Deco M4 two-pack delivers Wi-Fi to an area of up to 2,800 square feet. And if that's not enough, simply add more Decos to the network anytime to increase coverage.
Deco uses a system of units to achieve seamless whole-home Wi-Fi coverage — eliminate weak signal areas once and for all
A Deco M4 two-pack delivers Wi-Fi to an area of up to 2,800 square feet. And if that’s not enough, simply add more Decos to the network anytime to increase coverage.
Deco M4 provides fast and stable connections with speeds of up to 1167 Mbps and works with major internet service provider (ISP) and modem.
Deco can handle traffic from even the busiest of networks, providing lag-free connections for up to 100 devices
Parental Controls limits online time and block inappropriate websites according to unique profiles created for each family member.
Setup is easier than ever with the Deco app there to walk you through every step.
2-in-1 Router and Access Point Modes
Flexible and multifunctional, the Deco M4 includes a variety of features allowing it to serve as a router or access point. Just choose the mode for your actual network demands and experience the maximum wireless flexibility.
Engineered for More Devices
Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance
Seamless Roaming with One Wi-Fi Name
TP-Link Mesh means Deco units work together to form one unified network. Your phone or tablet automatically connects to the fastest Deco as you move through your home, creating a truly seamless Wi-Fi experience.
Experience Wi-Fi Like Never Before
Deco M4 uses TP-Link Mesh technology to cover your entire home in powerful Wi-Fi. Multiple units seamlessly work together to create a home network like nothing you’ve ever experienced.
Product Description | TP-Link DECO M4 - Wi-Fi system - Wi-Fi 5 - desktop | Device Type | Wi-Fi system - mesh | Enclosure Type | Desktop | Wi-Fi System Components | 3 routers | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz / 5 GHz | Network / Transport Protocol | PPTP, L2TP, PPPoE, DHCP, DDNS | Features | IPv6 support, parental control, Access Point operational mode, WMM support, QoS, DHCP server, static IP mode, port forwarding, reset button, IPv4 support, SPIF, dynamic IP mode, DHCP client, wireless extender mode, MU-MIMO technology, beamforming technology, router mode, guest access, DynDNS | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Dimensions (WxDxH) | 9.07 cm x 9.07 cm x 19 cm | System Requirements | Android 4.3 or later, Apple iOS 9 or later | Manufacturer Warranty | 3-year warranty |
Customer return - item has been opened but is in excellent condition
Ref: H3WY 048623 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
