ITEM | QTY | PRICE |
Lenovo USB-C 65W AC Adapter AC 100-24...
3 | £106.41 |
Armed with Wi-Fi 6 technology, Deco whole home mesh Wi-Fi is designed to deliver a huge boost in coverage, speed, and total capacity. Get on the mesh Wi-Fi to enjoy the future network that loads faster and connects more.
Faster Connections:
Wi-Fi 6 speeds up to 1,800 Mbps—1,201 Mbps on 5 GHz and 574 Mbps on 2.4 GHz.
Connect More Devices:
OFDMA and MU-MIMO technology quadruple capacity to enable simultaneous transmission to more devices.
Boosted Seamless Coverage:
Achieve seamless whole home coverage with a clearer and stronger whole home Wi-Fi signal generated by Wi-Fi 6.
Ultra-Low Latency:
Greater reduction in latency enables more responsive gaming and video chatting.
One Unified Network:
Multiple units form a whole-home network that auto-selects the best connection as you move around your home.
Total Security:
WPA3 encryption and TP-Link HomeShield provide personalized features, including Parental Controls, Antivirus, and Quality of Service (QoS) to ensure a safer online experience. Setup Made Easier Than Ever: The Deco app walks you through setup step-by-step.
AI-Driven Mesh: Always Learning, Constantly Optimizing
Armed with AI-Driven Mesh, Deco X20 delivers smart WiFi that follows you wherever you are, without interruption. It automatically learns your network environment, client quality, and user behaviors. Sophisticated algorithms account for various factors so that Deco X20 provides ideal mesh WiFi, unique to your home. Walk through your home and enjoy seamless streaming at the fastest possible speeds.
Engineered for More Devices
Deco products are aimed to dramatically improve capacity and efficiency in traffic-dense environments. No matter how many screens or devices are on at once, everyone is able to enjoy a more efficient network that loads faster without dragging down performance.
Greatly Reduced Lag, More Fun
Wi-Fi 6 brings stable and responsive Wi-Fi connections to tomorrow's hyper-connected home. Enjoy more responsive gaming and seamless video chatting even when multiple compatible devices are connected and transmitting data at the same time
Setup Just Got a Lot Easier
Unbox Deco, install the app and then simply follow the on-screen directions. Deco app will take care of the rest, getting your network up and running in minutes.
Product Description | TP-Link Deco X20 - Wi-Fi system - Wi-Fi 6 - desktop | Device Type | Wi-Fi system | Enclosure Type | Desktop | Wi-Fi System Components | 3 routers | WAN Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6) | Frequency Band | 2.4 GHz / 5 GHz | Performance | Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps | Network / Transport Protocol | PPPoE, DHCP | Routing Protocol | Static IP routing | Features | IPv6 support, parental control, Access Point operational mode, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, DHCP client, MU-MIMO technology, anti-virus protection, beamforming technology, band steering, TP-Link Adaptive Routing Technology, guest access, seamless roaming, black list | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax | Dimensions (WxDxH) | 11 cm x 11 cm x 11.4 cm | Weight | 2.66 kg | System Requirements | Android 4.4 (KitKat) or later, Apple iOS 9 or later | Manufacturer Warranty | 3-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA-PSK, WPA2-PSK, WPA3 |
Wi-Fi Rating | AX1800 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, VCCI, BSMI, IC, FCC, RoHS, KC, NCC, iDA, RCM, JRF, JPA |
Processor | Qualcomm 1 GHz |
Line Properties | |
Line Coding Format | 1024 QAM, OFDMA |
Expansion / Connectivity | |
Interfaces | WAN / LAN: 2 x 1000Base-T - RJ-45 |
Aerial | |
Aerial | Internal |
Antenna Qty | 4 |
Power | |
Power Device | External power adapter |
Installed Qty | 3 |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | Android 4.4 (KitKat) or later, Apple iOS 9 or later |
Dimensions & Weight | |
Width | 11 cm |
Depth | 11 cm |
Height | 11.4 cm |
Weight | 2.66 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
