Deco X60
£299.98
2 Pack
Eliminate weak signal areas with a clearer, stronger whole home Wi-Fi signal generated from Wi-Fi 6. No more searching around for a stable connection.
Faster Connections
Wi-Fi 6 speeds up to 3,000 Mbps—2,402 Mbps on 5 GHz and 574 Mbps on 2.4 GHz.
Connect More Devices
OFDMA and MU-MIMO technology quadruple capacity to enable simultaneous transmission to more devices . Boosted Seamless Coverage
Achieve seamless whole-home coverage with a clearer and stronger whole-home Wi-Fi signal generated by Wi-Fi 6.
Ultra-Low Latency
Greater reduction in latency enables more responsive gaming and video chatting.
One Unified Network
Multiple units form a whole-home network that auto-selects the best connection as you move around your home.
*Total Security
WPA3 encryption and TP-Link HomeShield provide personalized features, including Parental Controls, Antivirus, and Quality of Service (QoS) to ensure a safer online experience.
TP-Link HomeShield
Keeps your home network safe with cutting-edge features for network and IoT protection
Setup Made Easier Than Ever
The Deco app walks you through the setup step-by-step.
Product Description | TP-Link Deco X60 - Wi-Fi system - Wi-Fi 6 - desktop | Device Type | Wi-Fi system - mesh | Enclosure Type | Desktop | Wi-Fi System Components | 2 routers | WAN Ports Qty | 2 | Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6) | Frequency Band | 2.4 GHz / 5 GHz | Performance | Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 2402 Mbps | Network / Transport Protocol | PPTP, L2TP, PPPoE, DHCP, DDNS, IPv4, IPv6 | Routing Protocol | Static IP routing | Features | Content filtering, manageable, IPv6 support, IPS, parental control, Access Point operational mode, firmware upgradable, WMM support, QoS, DHCP server, port forwarding, reset button, IPv4 support, SPIF, MU-MIMO technology, anti-virus protection, beamforming technology, router mode, guest access, seamless roaming, black list | Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax | Power | AC 120/230 V (50/60 Hz) | Dimensions (WxDxH) | 11 cm x 11 cm x 11.4 cm | Weight | 590 g | System Requirements | Android 4.4 (KitKat) or later, Apple iOS 9 or later | Manufacturer Warranty | 2-year warranty |
General | |
Connectivity Technology | Wireless, wired |
Encryption Algorithm | WPA, WPA2-PSK, WPA3 |
Wi-Fi Rating | AX3000 |
Mesh Networking | Yes |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11r, IEEE 802.11v, IEEE 802.11ax, VCCI, IC, FCC, RoHS, RCM, JRF, JPA |
Processor | Qualcomm 1 GHz |
RAM | 4 GB SDRAM |
Flash Memory | 1 GB |
Line Properties | |
Line Coding Format | 1024 QAM, OFDMA |
Expansion / Connectivity | |
Interfaces | WAN / LAN: 2 x 1000Base-T - RJ-45 |
Aerial | |
Aerial | Internal |
Antenna Qty | 4 |
Directivity | Omni-directional |
Power | |
Power Device | External power adapter |
Installed Qty | 2 |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 24.5 Watt |
Miscellaneous | |
Cables Included | 1 x network cable |
Software / System Requirements | |
OS Required | Android 4.4 (KitKat) or later, Apple iOS 9 or later |
Dimensions & Weight | |
Width | 11 cm |
Depth | 11 cm |
Height | 11.4 cm |
Weight | 590 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
