802.11k and 802.11v seamless roaming provide seamless switching to the access point with optimal signal when moving between APs. Omada Mesh technology enables wireless connectivity between access points for extended range, making wireless deployments more flexible and convenient.
Product Description | TP-Link EAP225-Outdoor - radio access point - Wi-Fi 5 | Device Type | Radio access point | Form Factor | External - outdoor | Data Link Protocol | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Frequency Band | 2.4 GHz, 5 GHz | Capacity | Maximum number of configured SSIDs: 16 | Included Accessories | PoE injector, pole mount, wall mounting kit | Power Over Ethernet (PoE) Supported | PoE | Dimensions (WxDxH) | 4.6 cm x 2.7 cm x 21.5 cm |
General | |
Ruggedized Design | Outdoor |
Width | 4.6 cm |
Depth | 2.7 cm |
Height | 21.5 cm |
Networking | |
Form Factor | External |
Connectivity Technology | Wireless |
Data Transfer Rate | 867 Mbps |
Wi-Fi Rating | AC1200 |
Features | Load balancing, E-mail alert, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, pole mountable, weatherproof, rogue access point detection, Captive Portal, 802.1x authentication, Watch Dog Timer (WDT), Transmit Power Control (TPC), MU-MIMO technology, beamforming technology, scheduler, band steering, SSID to VLAN mapping, rate limit, Wireless Scheduler, VLAN management, Airtime Fairness |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac |
Aerial | |
Antenna Qty | 2 |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T (PoE) - RJ-45 |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Power | |
Power Consumption Operational | 10.5 Watt |
Environmental Parameters | |
Min Operating Temperature | -30 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
