Remote Access – Easy setup and control from anywhere with the free Kasa app (iOS, Android).
Scheduling – Schedule the Smart Plug to automatically power electronics on and off as needed, like setting lights to come on at dusk or turn off at sunrise.
Away Mode – Turns your devices on and off at different times to give the appearance that someone is home.
Voice Control – Pair to Amazon Alexa or The Google Assistant to enable voice control.
Manage Your Home Electronics and Appliances Anytime, Anywhere
The smart plug is easy to set up, and make it even easier to manage your household electronic devices anywhere in the world with a tap of your smartphone.
You’re Always Home
Add an extra layer of security with Away Mode. Connected devices will randomly turn on and off throughout the day to make it look like you’re home.
Modern, Elegant, Simple
Inspired by a modern sensibility, the smart plug's design is both simple and elegant, allowing it to blend seamlessly with existing decor.
Never Leave Things Running
The smart plug gives you a peace of mind with the count down timer feature, which automatically switches off the running household appliances (clothes iron and curling iron) if you have set a time limit before.
Your Voice Has Power
Control your device with simple voice commands and an Amazon Alexa, Google Assistant, or Microsoft Cortana.
Remote Access
Control devices connected to the Smart Plug wherever you have Internet using the free Kasa app on your smartphone.
Schedule
Away
Easy to Use and Install
Just connect the Smart Plugs to your Wi-Fi network and control using the free Kasa App on your smartphone.
Amazon Echo Voice Control
Amazon Echo (sold separately) lets you control devices connected to the Smart Plugs using just your voice.
Product Description | TP-Link HS100 - smart plug | Product Type | Smart plug | Connectivity | Wireless - 802.11b/g/n | Frequency Band | 2.4 Ghz | Supported Host Device OS | iOS, Android | Dimensions (WxDxH) | 6.63 cm x 7.7 cm x 10.03 cm | Warranty | 2 year warranty |
General | |
Connectivity Technology | Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Features | Power scheduling |
Miscellaneous | |
Power Provided | 3.68 kW |
Compliant Standards | RoHS, EAC |
Dimensions & Weight | |
Width | 6.63 cm |
Depth | 7.7 cm |
Height | 10.03 cm |
Weight | 131.8 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 90% (non-condensing) |
