TP LINK KC105 Kasa Smart Spot Cam with microSD slot
£39.99
10 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Secure local storage
  • Real-time alerts
  • Two-way audio
  • Activity zones
  • Live view
  • Stock Status: In Stock
Product codes
Bundle deals (2)
KASA STARTER KIT - BULBS AND SMART PLUGS
= £89.98
Save £30.00
KASA SMART POWER STRIP
= £64.97
Save £5.00
Keep an eye on your things with Kasa Spot indoor security camera. Receive instant alerts through Kasa app when your camera detects motion or sound activity. With all videos stored locally on MicroSD card, access your video history and live stream 1080p HD video on your smartphone, an Alexa or Google Assistant supported display.
Product Description TP-Link Kasa Spot KC105 - network surveillance camera
Device Type Network surveillance camera - fixed - indoor
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 5.9 cm x 4.96 cm x 8.86 cm
Weight 198 g
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 15 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type 1/2.7"
Focal Length Control Fixed focal
Focal Length 3.21 mm
Lens Iris F/2.0
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant Alexa ready, Google Assistant ready
Cables Included 1 - USB cable - external - 3.05 m
Voltage DC 5 V
Features Push Notification, reset button, Smartphone Monitoring, Audio Detection, WPA, WPA2-PSK, WEP
Environmental Parameters (operating) 0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK KC105 Kasa Sma...
£39.99
