The Kasa cam outdoor is a full-featured weatherproof security camera that you can access from anywhere. Day or night, rain or shine, Kasa cam protects what you love.
Protect Your Outdoors
Use crisp 2-way audio to communicate with the delivery person at your front door or use the siren to scare away intruders.
Crystal Clear Video
Sharp and clear, wide-angle 1080P video makes sure you never miss a thing. Manually zoom in to get a closer look to what's going on, day or night.
Easy DIY Install
Get the best angle and video with your Kasa Cam Outdoor with an easy to follow installation process in the Kasa Smart app. The magnetic camera mount and mounting wall plate make for a quick set-up and allows you to configure your camera for the best view.
Watch from Anywhere
Watch live or recorded video at any time on your smartphone with the free Kasa Smart app. Even stream live video to any Alexa or Google Assistant supported display, e.g. Fire TV or Google Chromecast.
Instant Notifications
Get instant alerts straight to your smartphone whenever your Kasa Cam Outdoor detects any sound or motion.
Weatherproof
The Kasa Cam Outdoor’s IP65 rating ensures your device will be protected against rain and dust.
Product Description | TP-Link Kasa KC200 - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor - weatherproof | Audio | Yes: built-in speaker, two-way audio capability, built-in microphone | Dimensions (WxDxH) | 7.395 cm x 7.355 cm x 8.628 cm | Weight | 310 g | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Max Resolution | 1920 x 1080 | Frame Rate (max) | 30 frames per second | Motion Detection | Yes | Video Modes | 720p, 1080p, 360p | Optical Sensor Type | 1/2.7" | Focal Length Control | Fixed focal | Focal Length | 3.21 mm | Lens Iris | F/2.0 | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac | Intelligent Assistant | Google Assistant, Alexa | Cables Included | 1 - USB cable - external - 3.05 m | Voltage | DC 5 V | Features | LED indicator, reset button, Audio Detection, built-in siren, WPA, WPA2-PSK, WEP | Manufacturer Warranty | 2-year warranty | Environmental Parameters (operating) | -20 °C - 43 °C; 10 - 95% (non-condensing) relative humidity |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: built-in speaker, two-way audio capability, built-in microphone |
Width | 7.395 cm |
Depth | 7.355 cm |
Height | 8.628 cm |
Weight | 310 g |
Camera | |
Type | Colour - Day&Night - fixed - outdoor - weatherproof |
Digital Video Format | H.264 |
Max Digital Video Resolution | 1920 x 1080 |
Digital Zoom | 8 |
Infrared LEDs | Yes |
Infrared Distance | 30 m |
Video Capture | 1920 x 1080 @ 30 fps |
Image Sensor | |
Type | 1/2.7" |
Lens Construction | |
Type | Fixed focal |
Lens Iris | F/2.0 |
Horizontal Field of View (degree) | 130 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac |
Network Protocols | TLS, SSL |
Miscellaneous | |
Included Accessories | Mounting kit, magnetic base plate |
Cables Included | 1 x USB cable - external - 3.05 m |
Compliant Standards | IC, FCC, IP65 |
Power | |
Power Requirements | DC 5 V - 1 A |
Power Device | Power adapter - external AC 120/230 V (50/60 Hz) |
Software / System Requirements | |
OS Required | Android 4.4 (KitKat) or later, Apple iOS 10 or later |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Type | Cloud |
Communications Technology | Wi-Fi |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 2 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 18.4 cm |
Shipping Depth | 15.4 cm |
Shipping Height | 10 cm |
Shipping Weight | 810 g |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 43 °C |
Relative Humidity (operating) | 10 - 95% (non-condensing) |
