The TP-Link LiteWave Series Unmanaged Switches provide easy and affordable way to expand your wired network. They are easy to use and reliable. With these plug-and-play switches, you can expand your network connections to multiple devices instantly. With all ports support Auto-MDI/MDIX, there's no need to worry about the type of cable to use.
Increase the speed of your network with the LS1005G 5-port Gigabit desktop switch. Non-blocking, 5× 10/100/1000Mbps ports enable instant transferring of large, bandwidth intensive files without interference.
Product Description | TP-Link LiteWave LS1005G - switch - 5 ports - unmanaged | Device Type | Switch - 5 ports - unmanaged | Subtype | Gigabit Ethernet | Ports | 5 x 10/100/1000 | Performance | Switching capacity: 10 Gbps , Forwarding performance: 7.4 Mpps | MAC Address Table Size | 2K entries | Jumbo Frame Support | 16KB | Features | Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, plastic housing, fanless, Green Technology | Compliant Standards | IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3x | Dimensions (WxDxH) | 9 cm x 7.2 cm x 2.3 cm |
General | |
Enclosure Type | Desktop, wall-mountable |
Status Indicators | Power, link/activity |
Expansion / Connectivity | |
Interfaces | 5 x 1000Base-T RJ-45 |
Power | |
Power Device | External power adapter |
Power Consumption Operational | 3.7 Watt |
Miscellaneous | |
Compliant Standards | FCC, RoHS |
Dimensions & Weight | |
Width | 9 cm |
Depth | 7.2 cm |
Height | 2.3 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 70 °C |
Humidity Range Storage | 5 - 90% (non-condensing) |
