TP LINK Tapo C200 Pan & Tilt Cam
limited time offer
price drop
USUALLY £29.99!
£22.99
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Detects motion and sends you alerts right away
  • Advanced night view helps guard you while you sleep
  • Privacy mode and safe local storage ensures your privacy
  • High definition video
  • Live view and two-way audio
  • Get a detailed look at your room
  • Type: Indoor Camera
  • Compatible With: Alexa, Google Assistant
Product codes
chevron icon
chevron icon
High-Definition Video
Records every image in crystal-clear 1080p definition
Pan and Tilt
360º horizontal and 114º vertical range
Advanced Night Vision
Provides a visual distance of up to 30 ft
Motion Detection and Notifications
Notifies you when the camera detects movement
Sound and Light Alarm
Trigger light and sound effects to frighten away unwanted visitors.
Two-Way Audio
Enables communication through a built-in microphone and speaker
Safe Storage
Locally stores up to 512GB on a microSD card, equal to 384 hours (16 days) of footage.
Voice Control
Free Up Your Hands with Voice Control: Works with the Google Assistant and Amazon Alexa.
chevron icon
Product Description Tapo C200 - network surveillance camera
Device Type Network surveillance camera - pan / tilt
Audio Yes: built-in speaker, two-way audio capability, built-in microphone
Dimensions (WxDxH) 8.66 cm x 8.5 cm x 11.77 cm
Connectivity Technology Wireless
Camera Colour - Day&Night
Max Resolution 1920 x 1080
Frame Rate (max) 15 frames per second
Motion Detection Yes
Video Modes 1080p
Optical Sensor Type 1/2.9"
Focal Length Control Fixed focal
Focal Length 4 mm
Lens Iris F/2.4
Panning Range (degree) 360
Tilting Range (degree) 114
Interfaces IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage DC 9 V
Features Alarm function, Motion Detection Technology, Privacy mode, Push Notification, microSDXC card slot, WPA, WPA2-PSK, WEP, WPA2, firmware upgradable
Environmental Parameters (operating) 0 °C - 40 °C; 10 - 90% (non-condensing) relative humidity
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£22.99
