Multiple Color & Effects - Control 50 separate color zones and bring vibrant joy to your life.
External Protection – Easy maintenance and extended lifespan thanks to PU coating.
No Hub Required - Connect to your home’s secure Wi-Fi network. No need for a hub or extra equipment.
Flexible Installation - Cut it to whatever length you want and attach it to any surface with the 3Madhesive.
Preset for Convenience - Found your favorite lighting for watching movies? Save it as a setting you can simply select for future movie nights.
Schedule & Timer - Create schedules and count plans to turn on/off with the brightness/color you set.
Away Mode - Simulate someone being at home to frighten away, unwanted visitors.
Connect It Your Way - Use it with your smart assistant, a hub, or connect directly to the Tapo App. Control the Light Strip however you want.
Voice Control - Use simple voice commands to control your light strip with Alexa or Google Assistant.
Product Description | Tapo L920-5 - light strip - LED - 13.5 W - 16 million colours | Product Type | Light strip | Light Source Type | LED | Usage Modes | Away | Wattage | 13.5 W | Colour of Illumination | 16 million colours | Dimmable | Yes | Intelligent Assistant | Google Assistant, Alexa - indirect | Platform | Apple HomeKit | Communications Technology | Wi-Fi | Voltage Required | AC 220 - 240 V | Frequency Required | 50/60 Hz |
General | |
Features | Remote controlled, 3M adhesive tape mounting, cuttable, app-controlled, lighting schedules, power on/off timer, Sync-to-Sound function |
Light Source | |
Type | LED |
Built-in LED Lamp | Yes |
Wattage | 13.5 W |
Dimmable | Yes |
Lifetime | 50000 hours |
Features | Colour changing LED, 1%-100% dimmable |
Power Requirements | |
Power Consumption Stand by | 0.4 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Hub | Not needed |
Compatible Application | Tapo app |
Intelligent Assistant | Google Assistant, Alexa |
Voice Controlled | Indirect |
Miscellaneous | |
Included Accessories | Power adapter |
Compliant Standards | RoHS |
Dimensions & Weight | |
Width | 1 cm |
Height | 0.16 cm |
Length | 5 m |
Weight | 57 g |
Shipping Dimensions (WxDxH) / Weight | 14.45 cm x 6.85 cm x 11.95 cm |
Environmental Parameters | |
Min Operating Temperature | -15 °C |
Max Operating Temperature | 40 °C |
