TP LINK Tapo P100 Smart Socket
FREE DELIVERY
£14.98
14 in stock
Delivery:
Standard: 1-3 working days
  • Type: Smart plug
  • Compatible With: Alexa, Google Assistant
  • Stock Status: In Stock
Product codes
Bundle deals (2)
GET VOICE CONTROL WITH ALEXA
= £49.97
Save £15.00
GET VOICE CONTROL WITH GOOGLE ASSISTANT
= £58.98
Save £5.00
Mini Smart Wi-Fi Socket
Remote Control
Instantly turn connected devices on/off wherever you are through the Tapo app
Schedule
Preset a schedule to automatically manage devices
Timer
Create countdown timer lists for connected electronics
Voice Control
Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant
Away Mode
Automatically turns devices on and off at different times to give the appearance that someone is home
Compact Design
Mini-sized to avoid blocking adjacent sockets
Easy Setup and Use
No hub required, set up quickly and manage easily through the free app
Product Description Tapo P100 - smart plug
Product Type Smart plug
Environment Indoor
Intelligent Assistant Google Assistant, Alexa
Connectivity Wireless - 802.11b/g/n, Bluetooth 4.2
Frequency Band 2.4 Ghz
Supported Host Device OS iOS, Android
Dimensions (WxDxH) 5.1 cm x 4 cm x 7.2 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
TP LINK Tapo P100 Smar...
£14.98
