Mini Smart Wi-Fi Socket
Remote Control
Instantly turn connected devices on/off wherever you are through the Tapo app
Schedule
Preset a schedule to automatically manage devices
Timer
Create countdown timer lists for connected electronics
Voice Control
Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant
Away Mode
Automatically turns devices on and off at different times to give the appearance that someone is home
Compact Design
Mini-sized to avoid blocking adjacent sockets
Easy Setup and Use
No hub required, set up quickly and manage easily through the free app
Product Description | Tapo P100 V1.2 - smart plug - 802.11b/g/n, Bluetooth 4.2 | Product Type | Smart plug | Environment | Indoor | Intelligent Assistant | Google Assistant, Alexa | Connectivity | Wireless - 802.11b/g/n, Bluetooth 4.2 | Frequency Band | 2.4 Ghz | Supported Host Device OS | iOS, Android | Dimensions (WxDxH) | 5.1 cm x 4 cm x 7.2 cm |
General | |
Connectivity Technology | Wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.2 |
Supported Host Device OS | Android 4.4 (KitKat) or later, iOS 9 or later |
Features | Away Mode, voice control, timer, up to 10 A, flame-retardant, up to 2990 Watt |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Aerial | |
Form Factor | Internal |
Miscellaneous | |
Product Material | Polycarbonate |
Encryption Algorithm | WPA, WPA2, WPA-PSK, WPA2-PSK |
Nominal Voltage | AC 220 - 240 V |
Compliant Standards | RoHS |
Dimensions & Weight | |
Width | 5.1 cm |
Depth | 4 cm |
Height | 7.2 cm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 10 - 90% (non-condensing) |
