ITEM | QTY | PRICE |
C2G 3m DB9 M/F Extension Cable - Black
3 | £27.84 |
Remote Control – Instantly turn connected devices on/off wherever you are through the Tapo app
Schedule – Preset a schedule to automatically manage devices
Timer - Create countdown timer lists for connected electronics
Voice Control – Manage your smart plug with voice commands via Amazon Alexa or the Google Assistant
Away Mode – Automatically turns devices on and off at different times to give the appearance that someone is home
Compact Design - Mini-sized to avoid blocking adjacent sockets
Easy Setup and Use - No hub required, set up quickly and manage easily through the free app
Product Description | TP-Link |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Aerial | |
Form Factor | Internal |
