Payday Tech Sale: The Biggest Brands. The Biggest Savings. Treat yourself to some new tech.
TP LINK Tapo RV30 V1 - Vacuum cleaner - robotic
£399.99
Delivery:
Notify me
Key features
  • 4200 Pa hyper suction
  • LiDAR and Gyro dual navigation system
  • Vacuum and mop combo
  • Customizable cleaning
  • Long time continuous cleaning
  • Auto-charging
  • Type: Smart Vacuum
  • Compatible With: Alexa, Google Assistant
Product codes
chevron icon
  • 4200Pa Hyper Suction - Sweeps away debris sandwiched between gaps and dust hidden in carpets for a deeper, powerful clean.
  • LiDAR & Gyro Dual Navi System - Accurately maps out your house in minutes, avoids omissions and repeated cleaning, and even works well in the dark.
  • Vacuum and Mop Combo - 3-level electronic mopping tackles sticky messes and kitchen grease for a more thorough clean.
  • Customizable Cleaning - Merge and separate areas, set cleaning schedule, and customize clean modes for each room.
  • 3-Hour Continuous Cleaning - 5000 mAh battery for long-lasting, fade-free suction.2
  • Auto-Charging - Returns to the charging dock automatically when the battery gets low, and then restarts right where it left off.
  • Carpet Auto-Boost - Increases the suction power when moving from a hard floor to a carpet.
  • Voice & Remote Control - Simply send voice commands via smart speakers or control via the Tapo app.
  • Real-time Voice Reporting - Keeps you informed about the robot‘s current status.
chevron icon
Product Description Tapo RV30 V1 - vacuum cleaner - robotic included charger
Product Type Vacuum cleaner
Cleaner Type Robotic
Compatible Floor Type General purpose
Cleaning Method Dry, wet
Control Type Electronic
Communications Technology Wi-Fi, Bluetooth 4.2
Platform Google Home
Intelligent Assistant Google Assistant, Alexa - indirect
Dust Collection Bagless
Operating Autonomy 3 hrs
Sound Pressure Level (SPL) 60 dB
Voltage 100 - 240 V / 50/60 Hz
Power Consumption 40 W
Charger Included charger
Dimensions (WxDxH) 34.1 cm x 34.1 cm x 9.5 cm
Weight 3.15 kg
Manufacturer Warranty 2 years
chevron icon
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used and shows signs of use
Ref: H8QQ 048478
£167.36
product
Ref: H8QQ 048478
Accessories
Packaging
Functional
Software
Manuals
£167.36
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£399.99
Notify me
