Built for your next Victory Royale, your latest achievement and much more with the Turtle Beach RECON 70 gaming headset for PS4 Pro and PS. Featuring Turtle Beach's lightweight and comfortable headset design for hours of play, with high-quality 40mm speakers and over-ear premium synthetic leather cushions that let you hear every crisp high and thundering low while blocking noise. Turtle Beach's renowned high-sensitivity mic to ensure you are heard clearly and easily flips up to mute. Finally, the versatile 3.5mm connection makes it perfect for swapping between PS4 and Xbox One controllers, Nintendo Switch as well as PC and compatible mobile devices.
Product Description | Turtle Beach Recon 70 - headset | Product Type | Headset - wired - 3.5 mm jack | Recommended Use | Game console, computer | Colour | Blue camo | Headphones Form Factor | Full size | Connectivity Technology | Wired | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 20 - 20000 Hz | Microphone | Boom | Microphone Operation Mode | Omni-directional | Controls | Volume, microphone on/mute |
General | |
Headband Material | Leatherette |
Earpad Material | Foam |
Audio Output | |
Frequency Response | 20 - 20000 Hz |
Diaphragm | 40 mm |
Magnet Material | Neodymium |
Microphone | |
Type | Boom |
Remote Control | |
Connections | |
Connector Type | Headset (mini-phone stereo 3.5 mm 4-pole) |
Cable | |
Cable Length | 1.2 m |
Miscellaneous | |
Included Accessories | Turtle Beach sticker |
Cable Details | Headset cable - 1.2 m |
