Meet Ultimate Ears BLAST, the super-portable Wi-Fi/Bluetooth speaker with bold, immersive 360° sound and hands-free voice control. Now with Amazon Alexa built-in, you and your crew can blast tunes, crank the volume, order takeout, and more, with just the power of your voice. Do it all at home or on-the-go, even take calls without killing the music whenever connected to Wi-Fi or a mobile hotspot. BLAST is waterproof, drop proof, and super stylin’ too — go from the shower to the beach party with confidence and style. Just say it to play it with BLAST from Ultimate Ears.
Product Description | Ultimate Ears BLAST - speaker - for portable use - wireless | Product Type | Speaker - for portable use | Protection | Dustproof, waterproof, drop-proof | Speaker Type | Active | Frequency Response | 90 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth, Wi-Fi | Intelligent Assistant | Alexa - direct | Colour | Yellow | Battery | Speaker battery rechargeable - Lithium Ion | Dimensions (WxDxH) | 18.8 cm | Dimensions - Diameter | 6.8 cm | Weight | 640 g | Manufacturer Warranty | 2-year warranty |
General | |
Microphone | Yes |
Enclosure Colour | Yellow |
Speaker System | |
Max Output Level (Max SPL) | 90 dB |
Interfaces | Bluetooth, IEEE 802.11a/b/g/n |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP) |
Transmission Range | 100 m |
Internet of Things (IoT) | |
Intelligent Assistant | Alexa |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Speaker: 2 x full-range driver - 1.38" , Speaker: 2 x Passive Radiator - 3.19 x 1.54" |
Miscellaneous | |
Included Accessories | Power adapter, micro-USB cable |
Compliant Standards | IP67 |
Max Depth of Water Resistance | 1 m |
Power | |
Power Source | Battery |
Battery | |
Type | Rechargeable - Lithium Ion |
Run Time (Up To) | 12 hour(s) |
Dimensions & Weight | |
Diameter | 6.8 cm |
Height | 18.8 cm |
Weight | 640 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 11.7 cm |
Shipping Depth | 11.7 cm |
Shipping Height | 20.6 cm |
Shipping Weight | 1 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
