Meet Ultimate Ears MEGABLAST, an incredibly powerful portable Wi-Fi/Bluetooth speaker with big, bassy 360° sound and hands-free voice control. Now with Amazon Alexa built-in, you and your crew can blast tunes, discover new music, order takeout, and more, with just the power of your voice. Do it all at home or on-the-go, even take calls without killing the music whenever connected to Wi-Fi or a mobile hotspot. MEGABLAST is waterproof, rugged, and stunning too - go from cocktail party to the pool party with confidence and style. Just say it to play it with MEGABLAST from Ultimate Ears.
Product Description | Ultimate Ears MEGABLAST - speaker - for portable use - wireless | Product Type | Speaker - for portable use | Protection | Dustproof, waterproof, drop-proof | Speaker Type | Active | Frequency Response | 60 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth, Wi-Fi | Intelligent Assistant | Alexa - direct | Colour | Blue | Battery | Speaker battery rechargeable - Lithium Ion | Dimensions (WxDxH) | 23.7 cm | Dimensions - Diameter | 8.8 cm | Weight | 1.2 kg | Manufacturer Warranty | 2-year warranty |
General | |
Microphone | Yes |
Enclosure Colour | Blue |
Speaker System | |
Max Output Level (Max SPL) | 93 dB |
Interfaces | Bluetooth, IEEE 802.11a/b/g/n |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP) |
Transmission Range | 100 m |
Internet of Things (IoT) | |
Intelligent Assistant | Alexa |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Speaker: 2 x woofer driver - 2.17" , Speaker: 2 x Passive Radiator - 3.35 x 1.97" , Speaker: 2 x tweeter driver - 0.98" |
Miscellaneous | |
Included Accessories | Power adapter, micro-USB cable |
Compliant Standards | IP67 |
Max Depth of Water Resistance | 1 m |
Power | |
Power Source | Battery |
Battery | |
Type | Rechargeable - Lithium Ion |
Run Time (Up To) | 16 hour(s) |
Dimensions & Weight | |
Diameter | 8.8 cm |
Height | 23.7 cm |
Weight | 1.2 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
