The Muvi Drivecam with GPS tracking captures your journey in 1080p HD footage that can be viewed, via the App, on your smartphone, tablet or PC. Fully equipped with motion detection for automatic start/stop recording and a G-Force sensor, so should your car be involved in a collision, your files will be automatically protected.
HD QUALITY
Quad-HD video quality 1080p@60fps
GPS TRACKING
GPS tracking with route mapping software
AUTO START/STOP
Automatically turns on and starts recording when driving, stops when you turn the engine off
DEDICATED APP
Reviewed footage via the App, on your smartphone or tablet
MEMORY
Micro SDHC up to 128GB, not included
Product Description | Veho muvi VDC-001-KZ1-F - dashboard camera | Product Type | Dashboard camera - 1080p | Memory Card Slot | microSD card | Sensors | Motion sensor | Wireless Interface | Wi-Fi | Sensor Resolution | 2.13 MP | Max Video Resolution | 1920 x 1080 | Lens System | Wide-angle lens f/2.0 | Focus Adjustment | Focus free | Display | LCD display - 3" | Real-Time Locations | GPS | Incident Detection | G-Sensor | Supported Battery | 900 mAh | Dimensions (WxDxH) | 11.44 cm x 3.7 cm x 7.19 cm |
General | |
Camcorder Sensor Resolution | 2.13 MP |
Sensor Qty | 1 CMOS |
Widescreen Video Capture | Yes |
Optical Sensor Type | Exmor R CMOS |
Optical Sensor Size | 1/2.8" |
Frame Rate (Max Resolution) | 60 fps |
ISO (Max) | 12800 |
Navigation | GPS receiver |
Digital Video Format | H.264 |
Interface | IEEE 802.11b/g/n |
Connectivity Features | Video playback via mobile device |
Lens System | |
Type | Wide-angle lens f/2.0 |
Max View Angle | 120 degree(s) |
Lens Construction | 6 elements |
Additional Features | |
Additional Features | Built-in speaker, Wide Dynamic Range (WDR), STARVIS sensor |
Dashboard Camera Features | |
Features | WDR technology |
Display | |
Type | 3" LCD display |
Display Form Factor | Built-in |
Microphone | |
Microphone Operation Mode | Mono |
Miscellaneous | |
Included Accessories | Car power adapter, windshield mount |
Battery | |
Battery Type | Manufacturer-specific |
Details | 900 mAh |
Memory / Storage | |
Supported Memory Cards | microSD Card, microSDHC Card, microSDXC Card |
Memory Card Included | No |
Memory Card Max Supported Size | 128 GB |
Video Capture | H.264 - 1920 x 1080 p - 60 fps |
Dimensions & Weight | |
Width | 11.44 cm |
Depth | 3.7 cm |
Height | 7.19 cm |
